  1. Heo2
    Heo2
    No they wont they were junk even before they left the factory
    the quality they have make cheap chinese **** looks like
    high quality aircraft parts
  2. lordairgtar
    lordairgtar
    Wow! Even trikes had ute body styles in Oz.
  3. moefuzz
    moefuzz
    :rolleyes:
  4. moefuzz
    moefuzz
    Life on the Canadian Home Front, 1941-1945
  5. moefuzz
    moefuzz
    Proud to stand beside our Brothers,
    -For Democracy
  6. moefuzz
    moefuzz
  7. moefuzz
    moefuzz
  8. moefuzz
    moefuzz
  9. barqsnut
    barqsnut
    from Pearl, MS
  10. pontman
    pontman
    That was how I saved the picture. First Chopper! Very cool photo.
  11. JD Miller
    JD Miller
    Photoshopped probable acme.cobblers
  12. JD Miller
    JD Miller
  13. JD Miller
    JD Miller
  14. GrizzGang
    GrizzGang
    from D/FW
    I have an old friend or is it friend that is old . Anyway he helped work on the car and was a longtime friend of Dave Anderson . He said the same thing about the location of the crew and that Anderson should have never run that track
  15. ehdubya
    ehdubya
    nope 2000 J-Rads were built 1922-3 until breaking front ends became a safety issue. Streamlining pioneer and Designer Paul Jaray maintained this was due to poor material.
    Testing the effects of streamling on pedestrians...
    truth is stranger than photoshop :p
  16. ehdubya
    ehdubya
  17. 11E
    11E
    from USA
    Additionally, I heard some talk there (which I was) to the effect that there was some desire to see a 1/8th mile track record set. This was monumentally poor judgment for a strip that puts one immediately onto a banked oval facing brick walls and guard rails with no provision for runoff or escape (take a google earth image view of CMS to see what I'm talking about). Ill handling cars like dragsters in general and rocket cars in particular are poorly suited to negotiate turns at high speed on a banked surface. (if there's a worse suited run scenario, it doesn't come readily to mind.). Additionally, the reported wreckers in the runoff area can only be reported by people who were not there. No such vehicles were present in the area. The only cars in the shutdown area were: 1. a streetcar 2. A breadvan pulling a trailer with a doorslammer on it, and a low level dragster perpendicular to the track with two crewmen suspending the front wheels of the dragster and the driver at the back of the vehicle. Moments later, the PolPacker strikes the two front crewmembers and dragster from end rotating it 90 degrees to be parallel with the strip and the PolPacker striking the grandstand was in the vicinity of the "Winston" lettering. Both crewmen were killed instantly, one largely severed in two. Officials should never had permitted those vehicles to be in that area and survival instincts would suggest that it's not in ones own interest to position yourself thusly. This was the wrong venue for high performance cars in the first place,and the officials/track marshals were negligent in monitoring where support vehicles and cars could be placed in the vicinity of the shutdown area. The event was poorly conceived and managed. Getting some runs at the CMS venue was paramount, when in fact, there was a perfectly suitable 1/8 mile strip just up the road on Highway16 at Shuffletown that did have adequate shutdown facilities. This did not serve Mr. Carrier's agenda, however.
  18. starwalker
    starwalker
    I don't know where this is, but Will Manley, my favorite librarian columnist, had it in his blog. WillManley.com is an entertaining look at being a librarian.
  19. Deuce Daddy Don
    Deuce Daddy Don
  20. Achtung Hilda? Don't you mean "Achtung Herman":eek:...................(Goering)
    Doc.
  21. raceron1120
    raceron1120
    1938 near Columbus OH. Buckeye Lake Park
  22. raceron1120
    raceron1120
    1938 Central Ohio
  23. raceron1120
    raceron1120
    1938 Circleville, OH
  24. raceron1120
    raceron1120
    1938 LosAngeles CA area:
    photo: LIFE online archives
  25. raceron1120
    raceron1120
    1939 Monticello FL
  26. raceron1120
    raceron1120
    1939 near Tampa FL
  27. raceron1120
    raceron1120
    OKAY. . . .:p
  28. raceron1120
    raceron1120
    1960 Santa Barbara CA
  29. Suddenlee
    Suddenlee
    from Sydney NSW
  30. raceron1120
    raceron1120
    1954 West Hartford CT
