Projects HELP! SBC Oil Pressure is going HAYWIRE!
Discussion in 'The Hokey Ass Message Board' started by Butcher's Shop Customs, Mar 17, 2012.
  1. Butcher's Shop Customs
    from Paducah KY
    My oil pressure in my 54 has always held steady somewhere in the 40 psi range while cruising, and jumps between 60 - 70 psi when you tromp it. After warming up, it idles somewhere in the 15 - 20 psi range.
    Just the other day while on my way to work, the pressure began to bob up and down slowly, and drop to less than 5 psi when I stomped it. Let out of it and go back into a 2500 rpm cruise, and the pressure goes back to 40. Stand on it, and it'll drop back to nearly nothing.
    -When the pressure drops, I have not heard the lifters. This would be at about 3500 rpm, and about 3-5 psi per my gauge.
    -I replaced the gauge with a new one as a test, and the results were the same.
    -The symptoms only occur after teh engine has warmed up to about 160 degrees.
    The engine is a 1990 GM 350 truck engine. RV cam, .030 over. Mid 60's cast iron GM intake with oil filler tube and breather cap, early aluminum Corvette valvecovers with PCV fitted into the RH one. GM points dizzy, not that that really matters.
    The engine has around 40,000 miles, and was bought from Jasper in 2004. I have never had any trouble whatsoever up until now, and this is the second vehicle I've had it in.
    What could cause the pressure to drop when I goose it? It almost acts as if there is a relation between the vaccuum and oil pressure, which doesn't make sense to me.
    Thanks for any advice or direction you can send my way...
    Evan
  2. brandon
    brandon
    Low oil level....? ****ing pan dry...? Pickup fell off pump?
  3. Id sure have a look inside the pan and at the pump and the pump drive components.
    Not tied to vacuum, but to Rpms going up.
    Just to confirm things, verify with a mechanical gauge. Things like wires, grounds, senders before going nuts.
  4. gasserjohn
    gasserjohn
    oil pickup problem
    over fill with oil reck.....................
  5. Deuces
    Deuces
    If your using an electric oil pressure gauge, It might be the sending unit going bad that screws into the block... I always use a mechanical oil pressure gauge in my car...
  6. seacat95
    seacat95
    I had a 94 350 that did the same thing, it had the factory electrical sending unit and swapping gauges repeated the results. I put a mechanical gauge on it and viola, problem fixed. I could have replaced the sending unit but I prefer mechanical. All the bases were covered above, I would pull the pan and check the pickup for sure.
  7. Deuces
    Deuces
    I once drilled a hole in the oil pump cover and the pickup tube for a .125" dia. dowel pin... That idea works also.. Sorry! I don't know how to weld... :eek:
  8. milwscruffy
    milwscruffy
    Cam bearings or electric gauge.
  9. LKWDBOY
    LKWDBOY
    from So Cal
    There is only 2 reasons why it would do that:
    1st one is the oil level is low resulting in the oil running away towards the back of the pan when you step on the gas resulting in ****ing air.
    2nd the oil pump pick up has changed positions or possibly fallen out of the oil pump.
    If you check the oil and its low, youre good. Add oil.
    If the oil level is OK, you better pull the pan and check out the scene just to be safe.
    Good luck. PM me if you have any questions
  10. Butcher's Shop Customs
    from Paducah KY
    Thanks everybody!
    Oil is not low, and it's a mechanical gauge Looks like time to drop the pan!
  11. milner3268
    milner3268
    from buffalo NY
    pickup loose or fell off
  12. Hot Rod Willys
    Hot Rod Willys
    from Ohio
    You could try over filling the pan to get the oil level up to the pump to see if the problem is in your pick-up.
  13. 48 Chubby
    48 Chubby
    Had this happen with a 1987 model engine. My problem was the pressure relief valve spring in the oil pump. The damned thing broke up, one long coil became 50 wire circles. I replaced the spring and cup, reinstalled the same oil pump and never had another problem with it.
    Please let us know what you find.
  14. Butcher's Shop Customs
    from Paducah KY
    Tried the overfilling thing, 2 qts. didn't help. Pan droppin time.
  15. dirty old man
    dirty old man
    Hate to be the bearer of possible bad news, but oil pr. going down in tune with engine vacuum (load going up) can also mean worn main bearings. A sensitive mech gauge with a 1/4" line will pick up the loss of pr. when the pistons are getting a heavier load of fuel/air mix and actually pushing the crank down and away from their oil feeds holes, allowing more oil to flow out and pr. to drop. In messing with worn out old cars for 60 years I've seen it more than once.
    Dave
  16. Well would this apply to a situation like his as in, "fine yesterday but not today".
    The worn bearing theory would be gradual & over time no? A catastrophic failure in bearing would be sudden but have many other symptoms.
  17. dirty old man
    dirty old man
    We're not talking "catastrophic failure" just yet, just an early warning to check the main bearings while the pan is off. Apparently not knocking (yet), not on the verge of a blowup if driven carefully.
    Dave
  18. Don's Hot Rods
    Don's Hot Rods
    from florida
    At first I was leaning toward a bad sender or wire connection but you ruled that out with having a mechanical gauge and then trying a second gauge.
    I'm betting oil pump or pickup. I had a GTO that the oil pressure light would flicker on as I came to a stop. Turned out the pickup tube had fallen off the pump and the oil was washing away from the hole in the pump when braking.
    Put a preluber on a drill and spin it to see what happens. also pull a valve cover and see if oil is coming out of the pushrods. Then pull the pan as a last resort.
    Oh, and look at the oil pump driveshaft and the hex hole in the bottom of the distributor, as well as the gear on the distributor. I rounded off a driveshaft one time and it would catch at low rpms and skip at higher rpms.
    Don
  19. Missed my point entirety Dirty.
  20. Deuces
    Deuces
    Maybe a kink in the line???.. Those cheap nylon oil pressure lines sometimes get bent out of shape..
  21. Butcher's Shop Customs
    from Paducah KY
    So far, looks like the motor is fixin to have to come out. The aftermarket crossmember I'm using won't allow the pan to drop far enough to clear the crank. Hoping I can just support the engine with a hoist and pull the crossmember out from under it.
    Pulled the dizzy, everything looked fine. I did have more crud than normal on my drain plug's magnet. Something has come apart...
  22. Butcher's Shop Customs
    from Paducah KY
    got a 200 stat, problems start at 160.
  23. petew
    petew
    from Mebane, NC
    Clogged or imploded oil filter ?
  24. Willy301
    Willy301
    Hope it isn't too serious BSC....Probably oil pump parts on your oil plug...
  25. Unkl Ian
    Unkl Ian
    Fram filter ?
  26. JC Sparks
    JC Sparks
    from Ohio
    Change out the gage and see what it reads. JC
  27. milwscruffy
    milwscruffy
    Nope :
  28. oldtom69
    oldtom69
    from grandin nd
    I agree w/Unkl Ian-fram filter?
  29. cylhead
    cylhead
    Check behind timing gear and there are three gally plugs,on rebuilt engines they can come out causing low oil pressure,they need to be staked in place,not a guarantee just had it happen before.
  30. Ohhh them nasty fram filters. I had forgotten people might still be using those.
