elgin camshaft advise
Discussion in 'The Hokey Ass Message Board' started by spikebot 81, Mar 18, 2012.
  1. spikebot 81
    spikebot 81
    I could use some help with a engine combo because I'm really camshaft stupid. The engine was ***embled and stored for 2 yrs and the owner has no paper work on the build. Fairly easy to ID most of the components but had to pull the cam for ID. Here is the combo
    355sbc with speed pro dished pistons, pro topline cast heads 180cc intake 64cc chambers. Compression 9.6 to 1. stock rotating ***b.
    Elgin cam E1120P
    http://catalog.elginind.com/app/Engine_tech.asp?part=E-1120-P&category=Camshaft+High+Performance
    The engine will be put in a 81 Vette. The car weights 3200lbs. 200r4 auto trans with 2200 stall. Stock rear gear 2:87. Not a daily driver or a show car. I do have a lead foot. Thanks for helping out.
  2. seb fontana
    seb fontana
    from ct
    You really need to get rid of the 2.87 gears...3.70's would let the cam work...imo
  3. Keither
    Keither
    If you have a question, call Dima Elgin, Elgin Cams in Santa Rosa Ca. 707 545-6115. He's forgotten more than most of us have ever learned.
  4. spikebot 81
    spikebot 81
    Yes your right, 3:55 was the plan but I'm outa funds
  5. spikebot 81
    spikebot 81
    Thanks Keither I'll call Monday
  6. sdluck
    sdluck
  7. joel
    joel
    I'd say the cam kinda fits the engine. Use the .015" thick steel head gaskets when you put it back together. Also a 600 cfm carb and dual plane intake ( Performer or similar) .
