Removing window sealant from window channels
Discussion in 'The Hokey Ass Message Board' started by 1970malibu, Mar 18, 2012.
  1. 1970malibu
    1970malibu
    from Minnesota
    I took some gl*** out of one of my cars and was wondering what's the best/easiest way to remove the rest of the old sealant from the window channels. I tried to take a razor blade to it but have made little progress. They must of leaked at one point because I have a combination of firm sealant and then there is some that is really soft and sticky and looks like it was just applied. Any tips or tricks for removing this stuff?
  2. william.ali.kay
    william.ali.kay
    from Milwaukee
    If paint isnt a concern, Ive have good luck with thinner and a paint s****er.
    Or a little heat and a s****er.
  3. 1970malibu
    1970malibu
    from Minnesota
    Forgot to say that paint isn't a concern as I need to patch a couple spots on the channels and will be repainting the car. Will have to give thinner a try, this stuff is ****s to remove!
  4. robertsregal
    robertsregal
    sounds like the old butyl and urethane, I used a sharp gasket s****er to get to metal area as far as remaining residue rolec grinder disc also wear gloves the residue of windshield bed hard to scrub off!
  5. I have a thin 12 inch straight blade screw driver that I keep sharpened as my number one tool. number two is a s****er that I narrowed it 1/4 inch. sometimes if I'm dealing with ureathane I add a propane torch
