How much stuff on your car actually works?
Discussion in 'The Hokey Ass Message Board' started by HotRod28AR, Jul 2, 2005.
  1. We wont even go there with the Model A, but as for my daily driven '59, my speedometer, odometer, tach, low-beams, horn, radio, and wipers just flat out dont work, and I gotta' manually work my blinkers. Someday I'll get around to fixing these things, but how many people have the "if it runs, drive it" mentality?
    -Dean
  2. sacred_piston
    sacred_piston
    Surprisingly my 67 Chevy truck have stuff that works, well now. I got headlights (high and low), turn signals (manual turn off one side), brake lights and a really big clock that has 2 knobs and used to be a c***ette player but only the clock works now. I hope to have back up lights someday when I get around to installing the switch that has been sitting in my glovebox for about 7 months now, BUT if it runs just drive it hell it's the summer.
  3. hotrod54chevy
    hotrod54chevy
    from Ohio
    in my car the vent cord has been cut so you gotta open it at the firewall from under the hood..surprisingly the heater works! the turn signals work but the hub that the switch is in is loose from behind the steering wheel so i have to pull it up to the wheel whenever i drive,plus the switch itself is about a foot long since i custom cut one to replace what was left of the stock ultra short one..the gas gauge doesnt work,and the CD player does and then doesnt..i wanna stick the stocker back in the dash,though...
    creepy
  4. Slag Kustom
    Slag Kustom
    all my cars every function works down to the clock gauges interior light reverse lights cigarette lighter. I go so far as to make sure any car with shaved handles has a cable back up. i hate cars that things dont work right
  5. The Shocker
    The Shocker
    Its odd but everthing on my daily '60 Chevy works except the speedo and the interior light,Well the interior light works but to turn it off you gotta take the bulb out.The dash lights are dim as Hell and the gas gauge is kinda moody but I carry a gas can in the trunk so who cares?I love this car ...
  6. dehudso
    dehudso
    Headlights
    Taillights
    Tachometer
    Oil Pressure Gauge
    Radio
    Horn
  7. Fraz
    Fraz
    from Dixon, MO
    MO state law requires a lot of stuff to work like high/low beams, turn signals, and the like. So that stuff works. Radio works too when I put the antenna back in it.
    No reverse lights. No heater due to the fact I tore out the busted *** core 2 winters ago. Also the factory clock quit who knows how long ago. Cig lighter is iffy, works, quits, works, quits, works, quits.....
  8. luketrash
    luketrash
    Everything worked when I bought it, but the plastic gear in the transmission 86ed, so I have no speedometer function.. The radio kind of hums, but I have a replacement I ebayed over the winter ready to go in. I haven't fixed the speedo drive gear because it's kind of nice knowing I won't surp*** my 3000 mile yearly limit for the insurance company.
    However, it all original 6v stuff with frayed cloth wiring. I'm sure the status of works/doesn't work rests on a fickle balance.
    However, I just drive it. I drive it in heavy traffic, but I don't take it out on the highway.
  9. oldskool55
    oldskool55
    from socal
    head lights
    tail lights (most of the time)
    hazards
    wipers
    radio
    keyless entry
    oil and vac*** guages no lights
    the lights in the original guage cluster work but none of the guages do:rolleyes:
  10. merc-o-madness
    merc-o-madness
    not much, so i will list what doesnt work,
    horn
    p***enger door
    alternator
    reverse light
    all my gauges dont work
    radio
    all the weatherstripping is shot
    clock
    sometimes my blinkers
    locks
    driver side vent window
    wipers
    sometimes my power brake booster
    ummmmmm
    heat
    yea thats my list, and i drive this car almost everyday
  11. Deuce Roadster
    Deuce Roadster
    :D
    OK....call me a gold chainer...... :) :)
    Everything works on the Roadster........I always get my 32 inspected by the NSRA guys and it always gets the Safety 23 pin......just makes sense to me to keep everything legal so the MAN has no excuse or reason to stop you and h***le you....
    No radio and No heater........it's a roadster :D
    Randy
  12. leadsleadolds
    leadsleadolds
    On my Rivi I have to open my door pretty wide to get my power windows to work. It ****s because when there are small parking places I have to stop open the door roll them up then park. People behind me like it the most.
  13. DocsMachine
    DocsMachine
    from Alaska
    What works?
    Um... just enough for it to be daytime legal. Brakes, steering, etc. Headlights (but no running lights) turn signals that blink on their own (but none in the front) and brakelights.
    Backup lights are still in a box somewhere. Speedo is a no-show. No gas gauge whenever the ground wire falls off. No factory ammeter.No factory temp. Aftermarket tach no workie.
    In fact, the only gauges that do work are the slapdash aftermarket vac and oil pressure. Well, okay, the stock oil pressure idiot light works.
    No horns. They're in another box. Two out of the eight factory interior lights work (two under the dash, two out at the end of each door, two on either sailpanel.) All the power windows work, but the rear quarters are slow and icky. Six-way power seats haven't worked since the first Reagan administration.
    Radio probably stopped working in the middle of an LBJ state-of-the-union. One of the three stock cigarette lighters works. At least the socket does.
    Heaters a nonissue. Not yet plumbed for water, none of the cables are connected- it's a refit from yanking the old AC and trying to install a stock heater-only. Thought I could just swap plenums, turns out I need to gut the dash and replace most of the ducting as well.
    Vac trunk latch is is, and works, but not yet connected to a vac source.
    Wipers work, washer don't. Car doesn't have flashers- they were an option back in '66.
    But the steering is tight, the brakes will give you change from your dime, engine is healthy, trans is solid, diff is quiet as a churchmouse.
    And it's on the street, moving under it's own power, and legally (mostly) daily-drivable for the first time since 1986.
    Screw the little stuff, I'm goin for a ride! :D
    Doc.
  14. Bugman
    Bugman
    Radio inop
    heater blower fan only works sometimes
    temp and oil pressure guage lights inop
    backup lights on a seperate switch
    blinkers don't blink with the headlights on(6V car)
  15. Baumi
    Baumi
    I hate stuff that doesn´t work. Either I fix it or I remove it. That´s why my 62 Impala has no longer a neutral safety switch and my 56 Bel Air got rid of its hazard blinkers.
    The speedo and the turn signals on my 34 Plymouth went out lately, I´m gonna fix it tonight.
  16. ROADRAT EDDIE
    ROADRAT EDDIE
    from New york
    You have blinkers?....BTW, Rain-Ex works well.....See ya there!
  17. 64deville
    64deville
    64 Cadillac w/ lots of power options
    Working: Power windows, 6 way power seat, automatic dimmer switch, high/low beams, tail lights, front interior lights, glove box light, power antenna,
    Non Working: Signal seeking AM radio, clock, rear interior lights, 1 brake light, and the highly problematic Comfort Control heater/ac unit.
  18. Baumi
    Baumi
    Oh yeah! My post should have been "... that´s why my 56 Bel Air got rid of its
    hazard blinkers AND windshield wipers...."hahahaha
    I double that, rainex rules!!!
    Chris
  19. InjectorTim
    InjectorTim
  20. Mojo
    Mojo
    doesn't work: heater (no controls), the rear quarter windows, the p***inger side window works some (manual, and stripped regulator gear), speedo just bounces around a lot, no horn, and now my turn signal switch is ****ping out. I've got alot of mechanical things needing fixed, I try not to think about it, so I won't get pissed at the car, but it's my own damn fault for not getting my lazy *** out and fixing it.
  21. Tony
    Tony
    I've gone too many years driving stuff that had thing's that don't work. Like wipers, horn, e-brakes..
    Now i try to get it all to work. I guess i just fell like i actually did something the right way :D.
  22. Digger_Dave
    Digger_Dave
    Let's see; what works in my '41?
    Well, the heater does'nt. Hey wait a min., I don't have a heater!
    Then the boost gauge isn't working; opps took the blower off.
    Other than that, everything is AOK.
  23. Mel
    Mel
    Due to the fact that MN state law pretty much only requires you to be able to stop if you want to drive, and have lights at night, just the basics work for me. Looks like that'll change if I stay in CA though... so here's what works...
    low beam
    high beam
    all blinkers but rear left... can't find the short to save my life.
    brake lights
    speedometer
    odometer
    oil pressure
    amp guage
    temp guage
    wipers
    heater is always on... no blower though
    radio works by way of the cig lighter
    dash lights work whenever they want
  24. The Shocker
    The Shocker
    I got my speedo on my '60 working.It works perfectly up to 15 mph,then it goes crazy.I liked it better when it didnt move at all.
  25. Boones
    Boones
    from Kent, Wa
    I have worked to get as much as I can on mine. The horn does not work (can not figure out how to make the factory 59 steering wheel set up work) but everything else does.........
  26. Can confidently say that everything on this car "works"
  27. Agrv8r
    Agrv8r
    all my important gauges work. The clock on the dash doesn't work and the tubes in the AM radio need to be replaced. The vacuum wipers are hit and miss for the most part.....and I need to trace a bad ground for a taillight but I've just been too lazy to bother with it, which I'm allowed because the Impala has 3 other functional taillights (and 2 functional backup lights).
  28. Digger_Dave
    Digger_Dave
    Ahhh, them was the good old days!
    I bet he didn't use a brain bucket either!
    Roll bars; what's a roll bar?!!!
  29. tommy
    tommy
    I know it's a generational thing and not meant to be a slam, but I'm not proud of the things I'm too lazy to fix or the things I don't know how to fix so I'll just keep that to myself.:D
