any one actually put castors on the rear of their lowered car?
Discussion in 'The Hokey Ass Message Board' started by hotdamn, Mar 21, 2012.
  1. Nads
    Nads
    from Hypocrisy
    They were actual casters, real ****ing heavy duty ones.
  2. Buzzard II
    Buzzard II
    One way it was done years ago was to use safe wheels, without swivels, with the heavy duty brackets already attached. Bolt them to the bottom rear of the rear frame rails. Use solid wheels if you can find them. Good luck!
  3. Ive seen them in the little books also, maybe it was the moonglow that had them?
  4. NuckinFutz
    NuckinFutz
    from GA
    We used to use them on every "lil truck" we built without adjustable suspension. It saved alot of rear rolled pans.
  5. Mike Rotch
    Mike Rotch
    from Easley SC
    Dat's me!!!! :)
  6. Mate had it in his vw combi in the front, worked very well over speed bumps.
    Use the wheels off a broken hydraulic jack cause you know there strong. Or here in Australia they make them for the backs of caravans, they just go on with two U bolts.
    Hope this helps.
  7. flatheadpete
    flatheadpete
    from Burton, MI
    I'd cut a notch in the frame rails and weld in a 'c' notch without cutting the vertical parts of said rails. Reinforce the outside of the rails and drill a hole for an 'axle' for a small wheel. Skateboard wheels come in a buncha diameters. Noone would really notice unless they were under the car. Would look like a bolted in x-member from any other angle.
  8. notrod13
    notrod13
    from long beach
    casters are a common place on lowered cars in lynwood........ and yes bags are for weed
  9. Voh
    Voh
    It's a little O.T. But a lot of campers have them. I think it's a good idea if done properly. Hang them down just a little bit.
  10. mikes51
    mikes51
    I welded a plate onto the bumper brackets, around where the brackets split into a Y shape.. Now you've got a flat surface that the hardware store casters can bolt onto. Mount them as far back as you can so they don't have to hang way down to work.
    gnichols, pretty clean installation. I used to have a caster next to my idler arm. That idler arm hung down below the frame. It wasn't a bearing caster so it made the strangest sound when it hit. That 4 or5 inch diameter caster never was meant to spin that fast when it hit the ground at 65 mph.:)
  11. badshifter
    badshifter
    I'd put airbags on the casters so you can lower them when needed saving the tin. That way you can piss off the anti bag guys as well as the anti s****e your bumper guys! Win Win Win
  12. I've thought about doing this too when I get my car back together. So lets see some pics of mounting brackets.
    On page 98 of The Rodder's Journal #53 you can see a set on a custom Chevy.
  13. Lone Star Mopar
    Lone Star Mopar
    Ive been needing to do this for awhile, some actul pics of set ups would be nice. Just something to keep from crushing the pipes pulling into the driveway. Did somebody say Nuggs? Im in...
  14. Atwater Mike
    Atwater Mike
    I can't believe there's a loooong thread about this. Fatman has a kit...or was it Heidt? Or...Roger Hart?
    Somebody, they got the idea from the 'Little Pages', about '54.
    I put 'em on my '56 Coupe De Ville, in '65. Nobody knew they were under there, (it's a 'lesson in geometry')
    Put them in a straight line between bottom of rear tire and 'asphaltus interruptus'.
    A 'roll' is better than a 's****e'. Ask any fat guy.
    (My '36 three window was the first time I ever used 'em. 1957. They were full 3" casters, mounted under the trailing edges of rear fenders. Grandma's driveway was steeeep!)
    Don't fret it, use 'em. They work.
  15. hotdamn
    hotdamn
    damn thanks for all of the info and support guys :)
    My 59 edsel at stock height drags if I have some one in the back seat goin in to my drive way as it is so when I lower it I will definitely try this out before doing it on my 54 chevy as it is very low and has a huge 53 caddy rear bumper.
    the funny think about the dank nugs is Im not that young and I dont even smoke weed, I just find it humorous.
    so does any one have any more pics???
    thanks mikes51 btw :)
  16. y-oh-y
    y-oh-y
    I had to put casters on the rear of my wifes car, never liked the look of um. Replaced the casters with 1/2" plate steel, bolted vertical to the frame. The edge of the plates hung 2" below the bumper and were rarely noticed.
  17. Taff
    Taff
    a mate of mine over here fitted them to his transmission cross member to help him over speed bumps. Apparently had to explain every years at his inspection what they were for! :)
  18. XXL__
    XXL__
    This is a common mod for the front of C4/5/6 Vettes, and there are at least a couple of companies that offer a "bolt on kit" for them. The ones I've seen use a high durometer skateboard-type wheel.
  19. isky1843
    isky1843
    Helped a buddy of mine install some that he "borrowed" of of a grocery cart. Seemed to work ok.
  20. hotdamn
    hotdamn
    I was thinking that a fixed (one position) solid wheel would probably hold up better?
    has any one used something softer like a skateboard wheel that didnt work out?
  21. 40fordtudor
    40fordtudor
    Way back when, in my hometown, there was a '51 Merc with castors fromt and back---barely noticeable but worked well.
  22. Dale Fairfax
    Dale Fairfax
    castErs! Castor is a bean from which CastOr Oil is extracted.
  23. redlinetoys
    redlinetoys
    from Midwest
  24. 1951Streamliner
    1951Streamliner
    from Reno, NV
    I just buy new exhaust tips every year or so :p :D
  25. Got a set on my '53 Chevy and I'm very happy, cuz I wouldn't have a rear bumper if I didn't! I saw it first in the "how to restyle your car" the one with the Blue Danube on the cover. I thought it was the coolest thing ever and I wanted a set of those when I build my first custom. The casters I used came from one of those big crates they use in trucks and they are about 4" in diameter. I've had them for about 16 years with little wear.
    If you look closely at the 10th pic in my profiles "lady luck" pictures you can see them.
    Klaus
  26. hotdamn
    hotdamn
    damn I hate it when I do that!!!
    oh the other thing I forgot to mention guys is the main reason I want to do this isnt about pulling in its about backing out, I have wrecked some sh*t backing out with hammered cars...
  27. olskoolspeed
    olskoolspeed
    from Ohio
    Thanks. I guess you can teach an old dog new "slang".
  28. tfeverfred
    tfeverfred
    Not to be a wise ***, but if it's dragging maybe it's TOO low?
  29. hotdamn
    hotdamn
    (in robot voice)
    does not compute???
  30. DRUGASM
    DRUGASM
    Haha, my Edsel s****ed more before I lowered it ( weird? ). We have been eyeing this for my buddies 55 Dodge. He backed into his shop from gravel to cement, caught the tail pipe, broke an exhaust manifold and bent the bumper bracket. I've seen them on the big diesel pusher motor homes, too.
