COE COE Picture thread (imported from main board)
Discussion in 'Off Topic Hot Rods & Customs' started by Duration, Oct 30, 2007.
  1. Locomotive Breath
    Locomotive Breath
    from Texas
    Man I really like the lines on that bed. Nice work. ^^^
  2. Novadude55
    Novadude55
    from CA
  3. spankster
    spankster
    droplord, those two '59 Chevies, are actually LCF's, (Low Cab forwards), & not COE's. The cab forward trucks actually have the engine forward of the cab, whereas the COE's have the engine under the cab.
  4. Marty Strode
    Marty Strode
    My COE project, E-350 ch***is,460 engine, long term project,much too long. Plan is to finish for summer.
  5. b-bop
    b-bop
    Very cool Marty, love the box. Join the COE group and start posting build photo's
  6. that is awesome..
  7. Marty Strode
    Marty Strode
    The sheet metal on this truck had only 53,000 mi. A friend gave me (2) bread trucks that had been modified to resemble prison transports for the filming of a movie. One had been rolled, the other was pretty good. I replaced the lower side on the good one. I cut the box off just ahead of the sliding doors. In the next installment I will show the box closed up. It is good to be on board here.
  8. Marty Strode
    Marty Strode
    I know I am showing the build in an odd order, it is the best I can do. I moved the "nose cap" of the Grumman back and fabricated a new front panel and corners. I cut in a window in the front of the box to accept a sliding window to match the one in the cab. My intent is to have a "sleeper capsule" in the front of the box, that is removable,with the windows it will have a "p***-thru" to the cab.The capsule will have it's own vent to the outside, so we won't have to breath the fumes of the Hot Rod or race car riding in the back.
  9. Marty Strode
    Marty Strode
    The cab all painted and rear window installed.
  10. Novadude55
    Novadude55
    from CA
    Tell me how you made that body dolly,(mig or arc)
    and what size tubing did you use. ?
    did you make it specific for this build?
    me likey! love the wheels too
    kinda cool when you have to make special tools:D
  11. Marty Strode
    Marty Strode
    I used 1" .083 wall tube, I have several of those carts, I just modify them as needed for the current application. Mig welded (nothing fancy).
  12. Marty Strode
    Marty Strode
    Instrument cluster .090 aluminum. A real trucker has to have a tach you know.
  13. LN7 NUT
    LN7 NUT
    What size of truck was yours originally? Mine is a 750 and it came with a tach.
    Mine also has the Lincoln 368.
  14. Marty Strode
    Marty Strode
    My truck was a 600. It was a flathead.
  15. evil1
    evil1
    Rich Roberts rig
  16. Tuff Tin
    Tuff Tin
    Looking good Marty!
    Mike
  17. Lytles Garage
    Lytles Garage
    Pretty cool Marty.. Chris
  18. gjcat56
    gjcat56
    Marty, are you running 16" rubber on that ch***ie?
  19. Marty Strode
    Marty Strode
    Yes they are 16's. I would like a bit larger tire and wheel combo, But I will stay with steel budds, regardless of size. Also thanks for the kind words guys.
  20. Good progress Marty,
    It's looking good!
  21. Marty Strode
    Marty Strode
    A couple more shots of the front of box, and one taken outside getting the cab back on.
  22. Marty Strode
    Marty Strode
    This one is a 48 that I started, Dodge motorhome ch***is, it had a 440 engine moved back and down in the frame. I sold it to a friend, who mounted a 460 Ford and C-6 in it. He is a master body man, it is now highly detailed and ready for a shiny black paint job. It got a good home, I will post some finished pics later this year.
  23. v8steel
    v8steel
    Hey Uncle Johnny;
    What was your method for getting the double-hump belt line into the panels you made for that bed? They really look nice. I need to do the same for a project I hope to start in a couple months. Thanks in advance for your help!
  24. kooscoe
    kooscoe
    Cool Looking Box truck Marty.
    You dont see them very much.
    Have fun Building.
    Koos
  25. Bernatello51
    Bernatello51
    Where and on what site?
  26. LowKat
    LowKat
    Looks like a good ch***is choice, fits the body well.
    This thread makes me want a COE.
  27. nyvp
    nyvp
    Wow keep em coming
  28. for my next trick, I will be building one of these, and I happen to know where there is a somewhat not rusty 40's cab :D but that's gonna be my little secret :D
  29. JF
    JF
    from Utah
    One I found last week, Luckily it was already sold or I would have been towing it home! :)
