Spring Painting
Discussion in 'The Hokey Ass Message Board' started by Kustom292, Mar 23, 2012.
  1. Kustom292
    Kustom292
    from Winnipeg
    What paint should I use to paint the springs in my ford custom 300? Coils in the front and leafs in the rear.
  2. I would use blue.
  3. Kustom7777
    Kustom7777
    from Austin, TX
    I like POR-15 for that sort of thing, because you can wirebrush 'em and brush it on,,,but if you prep them well, any good enamel should do the trick
  4. tb33anda3rd
    tb33anda3rd
    i wouldn't treat them any different than the rest of the ch***is.
  5. Kustom292
    Kustom292
    from Winnipeg
    Im just worried about flex and the paint flaking on the first ride
  6. 55Hydramatic
    55Hydramatic
    If you want durability then go with Imron. That stuff will resist just about anything!
  7. homeslice
    homeslice
    you could try powdercoating
  8. Rogue63
    Rogue63
    from New York
    If I was painting with the springs in car I would just wire brush all the loose stuff off and paint with satin chasis paint,if I was takeing the springs off I would clean and spray with black metal etching primer and a light coat of chasis black.They do slide when then work so no heavy buidup is needed .You just want them to be clean and presentable.
