Trick to fill finished tubing gap? NO WELD
Discussion in 'The Hokey Ass Message Board' started by JPMACHADO, Mar 24, 2012.
  1. JPMACHADO
    JPMACHADO
    from Not Listed
    I have some tubing on a roll cage that is already painted.
    There is a small <1/2" gap on about 1/3 of the cir***ference where a cross bar runs across and intersects a long straight run. Tubing is 1.75" OD
    Due to the purpose of the bar, I am not worried about the gap from a structrual standpoint. The bar was added to hold some things.
    Does anyone have a good way to fill the gap besides grinding and welding? It would be a very tight out of position weld anyway.
    I know I can come up with something, but usually someone on here has a really simple and practical way to do things. A way that would become obvious after I tried to do it myself.
    I want something that could stand up to the area being hose and bucket washed. It won't be under pressure.
    Thanks for any help,
    John
  2. belle
    belle
  3. chaddilac
    chaddilac
    Tape the hole off and put some seam sealer in it... then pull the tape off for a clean line.
  4. F-6Garagerat
    F-6Garagerat
    x 2
  5. JPMACHADO
    JPMACHADO
    from Not Listed
    How would you back up the seam sealer / jb weld so it didn't just push farther into the tube?
  6. chaddilac
    chaddilac
    Expanding foam... :)
  7. oj
    oj
    No! Abo****ely Not! No Filler! If you have a piece of steel tubing and it is part of a rollbar then it has to be welded! plain and simple. And a less than a 1/2" gap is unacceptable, replace that piece of tubing. You are using a welder, it is not a calking gun. Some gaps are unavoidable - the nature of joining some pieces together will require a gap - but all gaps are to be welded to give integrity to the structure.
  8. badshifter
    badshifter
    That's like glueing 2 lug nuts on the wheel to make it look like all5 are holding it on. You just DO NOT do it. Make it right.
  9. JPMACHADO
    JPMACHADO
    from Not Listed
    It's a nonstructural joint. It's an extra bar used to hold gauges, steering column, etc... I used it instead of tabbing out for column drop. There's a hoop about 17" in front of it that ties all side bars together.
  10. 3banjos
    3banjos
    from NZ
    May have answered your own question there. If it's holding your steering column I'd be wanting it welded.
  11. Phil1934
    Phil1934
    You don't want to weld as it is painted but if you fill it you would still have to paint over the filler so just weld it. Technically no grinding, but I would fill it with a patch, sand, then run a bead.
  12. cl350rr
    cl350rr
    I once saw a picnic table held together with mashed potatoes (scout camp) looked good but probably not a recommended way to repair
  13. Silly,
    Weld it.
    I won't even ask how a gap got painted, or why you're worried about it now.
  14. Xdrag48
    Xdrag48
    You could use the kit they use for the door bars to swing out,use a pin in both sides ,it is strong and you could remove it if needed...
    Steve
  15. Mr48chev
    You would have to check the rule book for the organization that runs the events the car should run in but I'd have to think that any piece that is welded into a roll cage is then considered a structural part of said roll cage. I don't think a pookie fix will fly in this case.
  16. richie rebel
    richie rebel
    you have to weld it,good night irene.........
  17. falcongeorge
    falcongeorge
    from BC
    Failed tech?
  18. rosco gordy
    rosco gordy
    This **** kills me, hows this work, can I do that GROW SOME BALLS
  19. Of course that's exactly what I was thinking, that why I wasn't going to ask.
    Hey guys, failed tech because my roll cage isn't welded properly. Problem is I've already painted it and ***embled the car. Anybody know of some good bubble gum I can fool the tech inspectors with because welding in there now is going to be a real *** ache.
    See I don't want to know that ^^^^^, because then this would be another thread that makes me want to set myself on fire.
  20. falcongeorge
    falcongeorge
    from BC
    Nicely sums up what I am reading between the lines...
  21. Cymro
    Cymro
    WTF filler on a roll bar joint not weld!!!! This guy sounds like he's tired of living!!!! Do it Properly, you'd have to paint the filler in any case, and if it were me I would really appreciate a steering column attatched to something solid.
  22. Fenders
    Fenders
    Holding the steering column is non-structural ? :confused:
  23. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Have some one else weld it .You can always blend a rollbar.........
  24. JPMACHADO
    JPMACHADO
    from Not Listed
    I'll probably end up welding it
    It's not a racer, won't be inspected, but it's better to be safe than sorry.
  25. Willy301
    Willy301
    Even if you do not plan on racing it, the next owner might, and if it actually makes it through tech with your bubble gum patch, and it fails in a wreck, it could hurt or kill the person who thought he had a roll cage...Even if you do not plan on selling it, do a search, this forum is full of heartache of guys having to sell their ride for one reason or another...or full of happy when someone actually offered a price that they were willing to part with it for....It happens.
  26. hellcat666
    hellcat666
  27. 29bowtie
    29bowtie
    Ah, another Darwin award candidate! Do it properly, then you never have to regret the decision!:eek:
  28. 32-3 WINDOW
    32-3 WINDOW
    from utah
    by a pack of bazoka joe bubble gum , chew the **** out of it , stick it in your crack and read the comic that comes with it , is this is even funnier than the sunday comics , hells bells man
  29. fifTsix
    fifTsix
    from TEXAS
    Ding ding ding! we have a winner!!
  30. silversink
    silversink
    STP stickers have hid a lot of ****
