40 ford colum shaft bearing where to get one
Discussion in 'The Hokey Ass Message Board' started by HELLMET, Mar 25, 2012.
  1. HELLMET
    HELLMET
    I need the bearing to center the steering shaft what to use can i put a regular temkin type in there? Thanks
  2. choppedsled
    choppedsled
    from Spokane WA
    I'm pretty sure Mac's has them.
  3. a40lover
    a40lover
    Iys a rubber bushing, and BOB DRAKE carrys em
  4. Killer
    Killer
    Bob Drake.
    HI BILLY!
  5. HELLMET
    HELLMET
  6. HELLMET
    HELLMET
    My colum still has the race or bearing in it still it spins freely does that bubber piece ride on that?
  7. lowkroozer
    lowkroozer
    Bob Drake has them ..Order a catalog from them while you are at it..They have every thing
  8. AJofHollywood
    AJofHollywood
    I have the solid rubber ones from Mac's, now 5 years later it's making some noise. Mac's offers ones with br*** bearings inside. Which might have not made noise.
  9. RICH B
    RICH B
    If your column has a bearing in it, which it appears to have in the picture, somebody has
    added it. It looks like a later model column bearing, maybe you just need the plastic or
    metal cone that fits snuggly over the shaft and engages the tin race on the bearing. You
    also need a pre-load spring that goes between the steering wheel hub and the cone gizmo. I used to get the cones and bearings at the Ford dealer, probably need to get them from an early Mustang place now-a-days.
    Added a couple of pictures from a Mustang place.
  10. HELLMET
    HELLMET
    I would like to put a bearing in there.
  11. AJofHollywood
    AJofHollywood
    Billy, how is the roadster coming along? Are we going to see it on the streets again soon?
  12. barry wny
    barry wny
    I had no tube so I made a column,1 1'4" roll bar tube. Tractor Supply has a flanged retainer bearing 3/4" inside I used. Restored my buddy's 39 truck, did the same thing, a few tacks with a mig to hold it. can squirt some oil in there $2.95 .
