The Mallory Super-Mag
Discussion in 'The Hokey Ass Message Board' started by Ryan, Mar 29, 2012.
  1. Ryan
    Ryan
    ADMINISTRATOR
  2. with tach drive ... hmmm i would be guessing for a truck big truck
  3. squirrel
    looks like for a Y block?
  4. Ryan
    Ryan
    ADMINISTRATOR
    No, it's definitely a high-performance part... Read the marketing material.
  5. alchemy
    alchemy
    I've got one for a SBC, but mine has a wider cap like the HC DuCoils (except the extra coil tower is a dud). I'll get some pics soon, but I have no other data.
  6. so that would narrow it down to t-birds and maybe nascar type higher rpm fords
  7. squirrel
    is there a part number on the box?
  8. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I know nothing and I'm kinda interested in learning. I can tell you that a friend of mine bought a Roto-Faze for his Chevy and that thing is huge and one big honkin' dizzy especially compared to my Mallory Dual point with the cool wire terminating cap.
    This is American man, Bigger is always better...you know that! (in my best Ricky Bobby voice)
  9. Ryan
    Ryan
    ADMINISTRATOR
    "525 RH" is printed on the mag...
  10. rhpope
    rhpope
    I have one exactly like this one except for the lower housing to fit a Chrysler. Note that the Advance side name plate does not have anything stamped in the boxes for the advance at a particular rpm. This means that there is a solid coupling between the lower housing shaft and the generator which means it is a locked mechanical advance. The ones with mechanical advance has a set of fly weights inside the lower housing and would have the specs for how many degrees of advance at a given rpm stamp on the plate. The Advance or retard scale with the needle is so that you did not have to loosen the regular distributor hold down clamp and you would loosen the band clamp and rotate the generator to change the locked base (or static) timing more easily.
    As shown in the paperwork, the magneto requires an external coil and specifically a Mag-Spark coil for this setup to work.
    As already stated, the base is for a Y Block Ford.
    Roger
  11. notrod13
    notrod13
    from long beach
    damn i wish i was lucky enough to find stuff like this ... it so looks for a y block .
    worth building a motor for hell a whole hotrod!
  12. theHIGHLANDER
    theHIGHLANDER
    I'm speculating here, and I draw my speculation from 2 things, the color and the hgt. I think it may be a marine hipo part or version. Crab caps are popular for marine applications, and the color (blue,water?) leads to the idea. Taller? Maybe for easier access in the engine. It looks to be fairly well sealed up too, but many mags are pretty well sealed for obvious reasons. The blue could simply be "Ford", but I have a Mallory with a crab cap and tach drive that's a marine Chevy part. I see similarities.
    Ok, since the number was posted while I was typing, and it has "RH" in the number, twin-engined boats have one spinning one way and the other opposite. Maybe?
  13. HEATHEN
    HEATHEN
    from SIDNEY, NY
    It looks like either Y block or small block Ford. I've got old Mallory catalogs at home that I can look it up in later this evening, if it hasn't been positively identified by then. I've seen Super Mag control boxes at swap meets that it would probably need in order to function.
  14. Slick Willy
    Slick Willy
    All the other "Super-Mag"s have an achievable horse power on the tag, such as one for a Ford 427 says "465 HP" and so forth.
    My thinking is that you have one that was set up for "525 RH~ Rear wheel horse power" for drag racing or nascar. with the variable timing on the side it would be easy for a crew member to tweak it here and there. the low crab cap may have been for hood clearance from say a 427 SOHC or 406 maybe?
  15. Ryan
    Ryan
    ADMINISTRATOR
    The paper work also talks about a "boost" switch... Something my ignition guy mentioned (GMC Bubba)...
    Essentially, if it's a battery started engine you switch the switch to "Boost" for starting. Once the engine is started, you switch it to "Run." I love little **** like that.
  16. Atwater Mike
    Atwater Mike
    Yes, the 'boost' would be 12 Volts to coil (Magspark transformer in this case) while cranking, a function GM uses at the starter solenoid.
    Mallory Magspark transformers had a resistor that dropped 'coil voltage', as did GMs.
  17. Carb-Otto
    Carb-Otto
    from FINkLAND
    I'd say also that it would be for Ford, derived from gear.
    I remember seeing some old voltage regulator which had bit similar "little ****". Regulator had switch for reversed polarity which helps when engine is being started, when it runs, switch is turned back to normal. Based on same fact that when you connect battery + and - to right poles on a generator, it starts to roll.
    Something like that...
    Mallory also had Rev-Pol distributor, where "rev-pol" stands for "reversed polarity". What it helps on a distributor, I don't have slightest idea...
    But they sure do look good! That is reason why I have one polished for my nailhead! :D
  18. GMC BUBBA
    GMC BUBBA
    I have a couple on the bench and have rebuilt a few for customers. Made a couple electronic using chrysler reluctor and GM HEI control modules as well.
    The basic idea was for the mag lower end to be a generator supplying its own primary voltage to the coil and not need a battery etc. I will get one up and running in a day or two and post a" how the hell does it work" post on this thread.
  19. Looking at the spec sheet, that thing puts out at least 2x its nearest compe***ion.
    Literature says its for the most extreme racing conditions.
    Cool stuff, I want one.
    Id look at the most extreme racing, record holders, and such from the time period ( late 50s did you say?) I bet something pops up.
  20. Wow! Ryan has stumped Jim (GMC Bubba). Made him drag out that ol' thinking cap. Who wouldda thunk? Can't wait to see that "how it works" post.
  21. VERNOR-GREEN GARAGE
    VERNOR-GREEN GARAGE
    from Michigan
  22. 421SD
    421SD
    from Elgin, IL
    the RH stands for Right Hand Rotation as oppose to LH which would be for a boat
  23. GreenMtnBoy
    GreenMtnBoy
    Blue caps on Mallorys identify marine units as I remember.
  24. guffey
    guffey
    This used a Mallory super mag with a conventional cap I couldn't fine a better photo
  25. GMC BUBBA
    GMC BUBBA
    Ok some more little **** for Ryan...:D
    My favorite Mallory piece is the Rev Pol Street / Strip dash switch.
    Little blue lamp show when in the race mode!!!
    When in street mode the ignition feed went straight thru the ballast resitor and byp***es the resistor in "strip" mode.
    Fond memorys of riding in a blue , 427 Galaxie with this switch mounted in my friends car. I think it ran twice as fast in the strip mode ..... didnt it ?????
  26. Bruce Lancaster
    Bruce Lancaster
    The 525 identifies the engine family it fits...don't have catalog here but someone will. Those numbers stayed the same until Mallory moved to China, though in products made after a certain time about 1970 they are moved into a longer number as in **525**x.
    The HP is the advance curve, high perf presumably...that info is changed into numbers in later numbers.
    I ***ume the RH means the thing came in reverse rotation for paired marine engines.
  27. Ryan
    Ryan
    ADMINISTRATOR
    Dude... Blue lights add horsepower. They have to!! Can you imagine if it were red? Jesus god... WORLD RECORDS would be had!!!! That is too cool.
  28. Vandy
    Vandy
    from L.A. Ca
    I also have the same mag, but mine has a Chevy base. I just had Zig freshen it up and I have never used it. These are the original Super Mags. The advance mechanism is easily adjustable by removing the base, you will see the curve is easily set.
    Van
  29. TERPU
    TERPU
    High performance Marine. The RH is for Right Hand due to some boats having a LH or left hand engine as well. Tach drive and flat cap are common boat stuff as well. The switch for boost is to act like an impulse coupler to snap the mag or make spark when turning slow. The faster a mag turns the more spark you get typically. The old mags I have for Bangers have impulse couplers to allow enough resistance or spring like action to snap the shaft around faster to generate a hot spark to start. once running it isn't needed. Modern Vertex Mags have a similar action and you feel it when turning the shaft. But this is from my memory and stuff I have. I have never owned a Super Mag, so it'll be cool to see how it turns out. That's a cool piece and may fit behind the 4-71 on the rear of the y-block. Firewall surgery would be worth it to run that. It's a very cool piece and eliminates alot of ignition woes if it has advance and still works. Congrats that's a *****in piece.
    Tim
  30. racer756
    racer756
    What a beautiful part!
    I love mags on street driven cars.
