Yesterday I fit a set of wilson welding lincoln backing plates on my roadster. Does anyone have a part # handy for front brake hoses that will work. Also anyone have a brake shoe part #.Mine came with 2 inch shoes and I need one for early ford drums. Thanks,Louie
on factory plates use shoe number #286-29 its 12x1.75 and hose #bh36722 raybestos works good too! this numbers are for factory plates so you should still call wilson to see if they would work with his plates.
Call Bob and tell him you need the narrower shoes and he'll probably ship 'em right out. The brake set my friend Richard received had the same problem but Bob fixed it in short order.
thanks for the replies guys.Flat top do you think the hose you listed would be long enough towork on a 32 frame? Darwin thanks I tried Bob but hes tough to get a hold of. Im sure he would exchange them.Louie
I'm looking for the same shoe also. I tryed all the local parts houses looking for the 286-29 12x1.75 shoe and it never came up. Is there another number for this shoe.My 2 inch shoe is rubbing I got my kit from speedway I called to order some 1.75 shoes they cant get them by there selves you have to get the whole kit there supplier wont give them the part number for just the shoes must be top secret. Everything I find in ford is 11 inch or 12 by 2 inch. Thanks
I just talked to so cal speed shop and they seemed quite knowledgeable. They said they had both shoes but i didnt ask about getting them separate of the backing plates.
If you have the br*** seats in your wheel cylinders and are using 3/16" line you probably need a BH49927 hose. This hose is 19" overall. I was not familiar with the other hose mentioned, so I looked it up, all the pictures show plastic wear rings on it , might not look good on an open wheel car.
