Help ID these backing plates...
Discussion in 'The Hokey Ass Message Board' started by thekid54, Mar 29, 2012.
  1. thekid54
    thekid54
    What are these? They're hydraulic and mounted to a '37-'40 Ford rearend.
  2. Bruce Lancaster
    Bruce Lancaster
    Post more pics...pull a drum if possible. I kinda think those may be '37-8 cable brakes with Ansen conversion.
  3. pasadenahotrod
    pasadenahotrod
    from Texas
    Those are early Ford mechanical backing plates that hev been converted to hydraulic.
  4. thekid54
    thekid54
    Don't have access to it right now and these are the only pics I have, but I'll see if I can get more.
  5. thekid54
    thekid54
    Hmm...interesting. Are these worth keeping, or would I be better off going with '40 juice brakes.
  6. pasadenahotrod
    pasadenahotrod
    from Texas
    I'd use stock 39-40 or 42-48 backing plates before using any old conversion.
    Sell them to someone who "needs" them and offset some of the cost of the correct parts.
  7. LOWCAB
    LOWCAB
    from Houston
    Those are model A backing plates.
  8. Bruce Lancaster
    Bruce Lancaster
    If A they would be 11", and I don't know where the iron ribbed drums would come from... these don't look A. They have Bendix looking hold downs showing and what looks like a rotated cable outlet bulge showing...but those pictures are very limiting.
  9. thekid54
    thekid54
    Drum diameter is 12".
  10. RICH B
    RICH B
    I was thinking the ribbing looked more like '36 brakes; but the axle bell is later. The pictures I have seen of the Ansen conversions showed Huck wheel cyls with a hole drilled next to them to access the adjustment notches, these were '32-'34 plates, maybe later
    plates were done differently.
  11. Bruce Lancaster
    Bruce Lancaster
    The chevy Huck cylinders were used because they could both apply the brakes and adjust the shoes, important since that had to happen in the same place on the '28-34 conversions. Others like the one pictured above have the stock adjusters at the bottom and cylinder at top, so did not need Huck type cylinder...but I have NO idea what they used.
    The ansen conversions were available as full kits for all the various models '28-34 and were heavily advertised everywhere for a long time. They must have been fairly common, yet I have never seen more than ****tered fragments.
  12. RICH B
    RICH B
    Yea, it would be interesting to see whats inside the drums the OP posted; but most of time
    the thread just kind of ends with no further info. Always neat to see what was done in the past.
  13. thekid54
    thekid54
    I'll crack them open and keep you posted...
