Help! On the road and need help with a front end id.
Discussion in 'The Hokey Ass Message Board' started by whiskey bump, Mar 28, 2012.
  1. whiskey bump
    whiskey bump
    This guy just text me a picture of what he's got. Any help would be greatly appreciated! ImageUploadedByTJJ1332977855.281290.jpg
  2. tfeverfred
    tfeverfred
    More info needed.
  3. hotroddon
    hotroddon
    Ha Ha - that's what he's asking for - more information.
    Old Chevy truck maybe?
  4. whiskey bump
    whiskey bump
    just popped into a store do I can upload more pics. Sorry this is all I have. Thanks again for your help. ImageUploadedByTJJ1332978211.685546.jpg ImageUploadedByTJJ1332978230.089032.jpg
  5. thunderbirdesq
    thunderbirdesq
    Maybe a smaller, grainier picture taken from further back might help?
    EDIT: I rescind the above comment.:D
    Not sure what that is, but it is OLD... no backing plate attachment point... no brakes? Hay wagon maybe?
  6. whiskey bump
    whiskey bump
    Well the craigslist post said it was a 32 ford front end. Obviously it's not. I'm not to savvy at identification. He's asking 75 bucks for it. If its worth it I might pick it up just cause. My brother has dealt with this guy before, he's weird as ****.
  7. thunderbirdesq
    thunderbirdesq
    Yea... '32 ford, haha! When in doubt, call it deuce parts! not even close... That looks like teens or 20's era machinery there, Somone who knows what that is may pay $75 for it, but I wouldn't give him $20 if I was building a rickshaw...
  8. whiskey bump
    whiskey bump
    Ha! These are the pics he sent me. Sorry to say this will have to do. I'd really like to keep my contact with this guy as minimum as possible. Like I said he's weird as ****.
  9. tfeverfred
    tfeverfred
    Yea.....:eek: I just thought whoever sent it might have said it's a car or truck. Still funny though!:D
  10. austinhunt
    austinhunt
    Webbing that holds kingpin looks similar to that on my graham axle but the strange linkage... not sure.
  11. Atwater Mike
    Atwater Mike
    That's a 1924 Dodge axle. (Reverse Elliott spindle/axle design)
    Those spindles and that axle make a terriffic front axle for a cl***ic Indy (or "Big Car")
    That's what I'm using mine for. Oh, the lug pattern is 5 on 4.5" circle: same as '49-'67 Ford. Also easy to make plates for disc brakes. Wheel bearings are still good numbers.
  12. whiskey bump
    whiskey bump
    Thanks, that's good to know!
  13. rancid737
    rancid737
  14. tfeverfred
    tfeverfred
    "real vintage 19 32 dues front"
  15. whiskey bump
    whiskey bump
    Could it be a ford not a dodge? This is what he text me. Sorry if this is getting o/t
    "The why does it say ford right on it then i knew u another craigs list flake Outlaw Stuie the kid"
  16. JohnEvans
    JohnEvans
    from Phoenix AZ
    Ford did not use parallel front springs untill 48 on PUs. It ain't a Ford ! Early Dodge would be a good guess also. $25 if you really want a odd one.
  17. hotroddon
    hotroddon
    Sure looks like a 6 lug to me - I can see 5 lugs in one pic and judging by the pattern there has to be one behind the hub that can't be seen. Or so it looks to me .....
  18. tommy
    tommy
    Yeah I counted 6 lugs myself. I'd say Chevrolet. I've never seen a Dodge with 6 lug nuts.
  19. Heo2
    Heo2
    Nothing ford on that axle. maby you can
    use the spindles to lower a Model t
  20. antiqueautomike
    antiqueautomike
    from Spokane
    The axle is early Chevrolet like 1926-31. King pins are larger than Model T but the spindles can be adapted to fit. The hub interchanges with T.
    Mike
  21. Mike51Merc
    Mike51Merc
    Looks like a mid 80's Honda XL with the early pro-link single rear shock suspension.
  22. Looks like good s****.
  23. thunderbirdesq
    thunderbirdesq
    THis guy is obviously a complete a waste of a good piece of skin...
    Absolutely 100% positively nothing ford about it. Tell him to go pound sand...
  24. Ghost28
    Ghost28
    It looks just like the front axle I took out of my 27 chevy coach. No brakes on the front at all, from the factory.
  25. Mr48chev
    I'm pretty sure you are on the road in either Richland, Pasco or Kennewick Wa and that's the axle I gave a guy who bought a flathead from me a few months ago along with a bunch of other pieces he talked me out of.
    I never did know what it came out of as it was was sitting in my mom's companion's junk pile when we cleaned his old yard up.
  26. whiskey bump
    whiskey bump
    Nahh I'm in north Idaho. After he said there was a ford log on it I asked for a pic, then his phone coincidentally was failing to send pictures. I just left it at that. He already wasted enough of my time.
  27. donnymopar
    donnymopar
    from MI
    It's not 24' Dodge...24' Dodge is 5 lug and 5 on 6.5 or thereabouts.
  28. Mr48chev
    Yuppers, you can see that the hub (s) in photos that show closer photos of the hubs are 6 lug hubs. That's not the one I had though a some blacksmith had taken the one I had and cut off tie rod and flattened and drilled the remaining ends to bolt them to the bolt holes where the U bolts went.
