bed sills on a 42 Chevy 1/2 ton pickup
Discussion in 'The Hokey Ass Message Board' started by jcrich54, Mar 31, 2012.
  1. jcrich54
    jcrich54
    Hi, I'm working on a 42 1/2 ton Chevy pickup and it is a stepside short bed and was wondering, there are three bed sill crossmebers for that bed and I know where two go, the one in the front and the one behind the rearend that bolt to the frame, but not sure where the three one goes, and does it bolt to the frame too,also do you need to put angle iron on the side of the bed for a wood striped bed, thanks for any input and if anybody have any pictures they can post that would be great
  2. jcmarz
    jcmarz
    from Chino, Ca
  3. jcrich54
    jcrich54
    I did check that out, when I got my truck it had three crossmembers plus the rear that hold the bed sides together, so I take it that the third one is the rear one that bolt the side together
  4. tb33anda3rd
    tb33anda3rd
    there is a crossmember that doesn't rest on the ch***is, it just joins all the wood. the bed strips will indicate it's location. when i ***emble the beds i weld it to the bed sides so i can paint it in one piece and then drop the wood into place.
  5. jcrich54
    jcrich54
    thanks for the help
