What is the most invaluable tool you own?
Discussion in 'The Hokey Ass Message Board' started by RagtopBuick66, Mar 31, 2012.
  1. RagtopBuick66
    RagtopBuick66
    I was going through my "yard bags" the other day in an attempt to condense four bags into just one for my trip out to the salvage yard. When I finished, I realized that many, if not MOST, of the tools I had chosen to go into my primary bag were tools that I had made myself to perform a specific task at one time or another, and then along the way found other uses to which they were suited.
    A great example is the hubcap pry-s**** I found in the trunk of a newer model Benz. Initially I grabbed it out of the trunk because I needed an extension to remove a tough exhaust manifold bolt on a Buick 300 V8. When I was done, it got tossed in my tool bag. I forget exactly why, but I ended up grinding the edge of the s**** to about paper thin on the bench grinder. Now, I use it all the time. I can use the beveled edge to get behind stainless trim, and the wide flat edge makes it easy to pop it off the mounts without damaging the trim. I also use it to gently pry intakes free after I've taken out all the bolts. I just position it on the edge of the gasket and tap it in. A slight push downward, and 'POP'... mani is free.
    Some of the other tools are store-bought, obviously. I'd be lost without my Craftsman 19.2V impact wrench, my Snap-On ratcheting stubby screwdriver, and my Irwin 90-degree wire cutters. Can't forget about the Wiss M4R metal snips with dual edge, which prevents crimping the sheet metal by removing a strip of steel while I cut, or the extending 3/8" drive ratchet with the pivoting head.
    So I got to wondering... What tools do you most covet? What interesting tools have you MADE to perform a task, only to find it had a million more uses? What one tool would you be absolutely lost without?
  2. phillips screw driver or a hammer would hate to lose either
  3. my ears.
    and pliers
  4. Beau
    Beau
    The internet.
  5. Stroker McGurk
    Stroker McGurk
    from Canada
  6. Fenders
    Fenders
    Look lower.....
  7. Bridgeport !
  8. Ghost of ElMirage
    Ghost of ElMirage
    my brain? NO WAIT!! COMMON SENSE!!!!!!!!!!!!!
  9. RagtopBuick66
    RagtopBuick66
    I actually picked up a NICE BFH the other day... Can't say I was shopping for one, but when I saw it I had to have it. It's made by Dead-On, and I believe it is actually intended to be used in framing. I haven't framed **** in YEARS, so I didn't get it for that, but it does have a bottle opener...
      27.8 KB
  10. wojojo
    wojojo
  11. Babyearl
    Babyearl
    Too much mythbusters,,:D
  12. cuznbrucie
    cuznbrucie
    Has to be my electric drill, ***ortment of screwdrivers, hammer, and port-o-power!
    CB
  13. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    My health
    My family.
    My dogs.
    Shop towels.
    Hammers.
    Gas torch set.
  14. Shaggy
    Shaggy
    from Sultan, WA
    the HAMB....
  15. ARNIE
    ARNIE
    Leatherman!
  16. my 1/2" impact wrench
    my LOOOOOONG mac tools pry bar
    12v dewalt 3/8 impact driver (i use this sh!t on everything!)
  17. Donaz
    Donaz
    from Phoenix
    My VISA card
  18. OldCrow
    OldCrow
    glock. to protect everything else that's important to me.
    Russ
  19. flatheadpete
    flatheadpete
    from Burton, MI
  20. Bar Ditch
    Bar Ditch
    from Tacoma
    Yep!
  21. firingorder1
    firingorder1
    My big hammer. It fixes everything except electrical problems.
  22. captainjunk#2
    captainjunk#2
    the bandaid , no matter how carefull i am ,i always manage to lose some skin
  23. M_S
    M_S
    from SoCal
    Hit harder.
  24. graveyardsledder
    graveyardsledder
    I have a Snap On electric screwdriver with a 1/4" adapter and a my 3/8 electric impact, I use them everyday all day long. my mobile coppressor is nice too when I can get my truck to stuff in the woods.
  25. saxet
    saxet
    from Texas
    I agree.
  26. janko haus
    janko haus
    1) Welder
    2) Grinder w/ cut off discs
    3) Pick hammer
  27. go-twichy
    go-twichy
  28. cmbrucew
    cmbrucew
    from Socal
    Webb mill, logan lathe, and miller plasma arc.
    also Snapon and proto pullers.
    Bruce
    Works good
    Lasts long time
  29. Boyd Who
    Boyd Who
    The key to my shop.
  30. K13
    K13
    Lathe by far. There are lots of tools I love and wouldn't want to be without but I could use something else to do the work of just about any one of them without making the job too much harder but I would be hard pressed to duplicate what I do on my lathe with any other combination of tools.
