Buying car with title but no vin?
Discussion in 'The Hokey Ass Message Board' started by Lostj, Apr 1, 2012.
  1. Lostj
    Lostj
    from Miami, FL
    Hi,
    I found a car that I want to buy & I asked the owner for the vin so that I can get an insurance binder.
    He told me that the car doesn't have a vin but that he has a ***le.
    He bought the car with no ***le & got a ***le after applying for it at the dmv.
    I was under the ***umption that they ***ign a vin plate to the car in these situations?
    Anyone have any advice?
  2. Retro Jim
    Retro Jim
    Stay away from that car and keep looking . Can't get a ***le without a vin plate from any state that I know of . Sounds like he got a ***le someplace to sell to someone like you . No ***le is one thing but no vin tag is worthless . You can always get a ***le or bill of sale for states that don't use ***les with older cars .
    Retro Jim
  3. scottybaccus
    scottybaccus
    Sounds odd. Call your state's central DMV, not a branch. Get an executive statement of the requirements and procedure.
  4. rld14
    rld14
    If that car doesn't have a vin that matches the ***le, run away from it, it's very possibly stolen, especially in S Florida.
  5. slddnmatt
    slddnmatt
    what kind of car is this?
  6. uncle buck
    uncle buck
    The ***le doesn't exist without a vin number. The DMV will normally ***ign a state vin number if there is nothing found before issuing a ***le. His story doesn't add up.
  7. saltracer219
    saltracer219
    Almost all cars have a secondary V.I.N. If you tell what make, model and year is maybe I can tell you where to look to find it.
  8. B Ramsey
    B Ramsey
    i wouldnt run away just yet. what kind of car is it? are reproduction vin tags avail for it?
  9. Mr48chev
    There has to be a vin number on the ***le. It may not be to that exact car but there has to be a vin number on the ***le or it isn't a ***le. It sounds like he put the car together and then bought an old ***le to use with it. That is pretty suspect these days. I'd p*** or figure that I was going to have to jump through a bunch of hoops to get a clear ***le to it that actually fit the car after it was inspected an had a state issued vin ***igned.
  10. Save yourself alot of pain and just walk away......
  11. check it against the number on the engine, that was done too, but it does sound fishy, I think i would walk away....
  12. Lostj
    Lostj
    from Miami, FL
    Thanks guys. I'm going to call my DMV then ill ask him for the vin on the ***le and to check the vin the motor.
  13. Lostj
    Lostj
    from Miami, FL
    Btw, The car is a model T
  14. A Rodder
    A Rodder
    Vin number is on the frame, roughly under the body where the seats would be. And if memory serves on the block as well, we can all ***ume the block is not the original block though.
    Search specifically on Vin number locations on the model T.
  15. Dale Fairfax
    Dale Fairfax
    Now that you've told us it's a Model T; why don't you go over to the Ford Barn Model T forum and pose that question. I didn't think "T"s had any numerical I.D.
  16. jaysberman
    jaysberman
    Had the same problem, the state gave me a ***le in my name and I had the state police fill out one of their forms for a vin number--Pa. They were very helpful.
  17. MikeRose
    MikeRose
    from Yuma, AZ
    Early T's had the vin on the engine block and the # would be stamped into that blank area of a rebuilt engine if the original was to be replaced a lot of times, but it could be left blank or even have another # on it if the engine came out of another car.
    I'm not an expert by a long shot though.
  18. alchemy
    alchemy
    Ford didn't start putting the ID number on the frame until mid/late 1926. They were also on the side of the engine block since the beginnings of Ford. What year is your T?
  19. Bruce Lancaster
    Bruce Lancaster
    T original # was on the engine. likely changed by now of course. 1926 and 1927, MAYBE some 1925, have a frame number on top of rail under removable part of front floorboards. You can see how most T's are a problem...
    State ***le...is it for the Ford number (sequence from 1 in 1908 to 15,000,000 in 1927) or a state ***igned number, lilely something like FL-short number? If state ***igned, they rivet on a plate...no plate, no good.
  20. 55 dude
    55 dude
    i own a 60's wagon with ***le in my name and the vin tag has since dropped off. some time in the future i will take it down to the state patrol and have them inspect it and re***ign a vin number.
  21. Run Forrest, run!!!!!
  22. Lostj
    Lostj
    from Miami, FL
    Thanks for all of the advice, I ended up p***ing on it for a few reasons.
    I was sort of settling on the T b/c I couldnt find a model A that I liked but I'm just going to keep looking.
