Welder wanted to teach a high school robotics club how to weld
Discussion in 'The Hokey Ass Message Board' started by kellym, Apr 4, 2012.
  1. kellym
    kellym
    from Menlo Park
    I mentor a high school robotics club in the San Francisco bay area and we are looking for a welder who could provide us some instruction on how to weld aluminum tubing using a mig welder. We can stick two pieces together but it's not pretty or strong. Please PM me for more information.
    Kelly
  2. You can't weld aluminum with mig as far as I know...
    Taking the hamb to the streets ;)
  3. Elmer Rodger
    Elmer Rodger
    from San Diego
    spoolamatic?
  4. treb11
    treb11
    clean the surfaces thoroughly with a virgin stainless steel wire brush. aluminum forms a thin exterior layer of aluminum oxide which is much harder to penetrate on arc start.
    what is the alloy of the material being welded? need to pick a wire to match
    Wire diameter to match the thicknesses being welded together, gas to match the wire, correct polarity, set wire speed and and current settings starting with the base settings provided by the wire manufacturer or a reputable reference book.
    practice on s**** before trying the actual part.
    a trip to a good welding supply store can get you in the ballpark.
  5. gassersteve
    gassersteve
    Why not build a robot that can weld?
  6. gnichols
    gnichols
    from Tampa, FL
    That's what I was thinking! Gary
  7. Ruggie
    Ruggie
    c02 and aluminum wire can be used on any mig welder except for gasless.I use this setup at work and on a small mig i have at home.
  8. vividlyvintage
    vividlyvintage
    Where are you located? I am in hayward. I know a welding teacher that would most likely be willing to weld any aluminum you need welded for free. It will be tig welded not mig, so it will be prettier and stronger. can give you the info if you would like.
    thanks,
    Douglas Johnson
    "Skrach"
    www.VividlyVintage.com
  9. harley man
    harley man
    Wish I was closer I would help you.
  10. Noland
    Noland
    The guy I know that does alum weldeing also cleans the surface with acetone before welding. Yes you need a spool gun to weld aluminum with a mig or a push/pull gun because the aluminum wires so soft itll kink if you try to just push it threw the liner.
  11. specialk
    specialk
    From what I understand, you also need to use 100% argon - however, IANAW
  12. iamben
    iamben
    You don't need a spool gun to weld aluminum, you just need a mig welder that is set up for aluminum. We weld aluminum without a spool gun in a mig welder daily. Someone must know someone to help this guy out. Maybe even talk a little car talk while teaching them to weld aluminum!!!!
  13. squirrel
    We had a freshman weld the ch***is for the FRC team 1726 robot this year. The trick is to be more open minded about material selection. We used thinwall steel tube and 1/8" steel angle and strap to make the ch***is. Having all that weight down low means you need to make the rest of the robot light...which helps keep it from tipping over. We used thinwall aluminum tube and other lightweight materials for the top, mostly riveted together.
    the kids painted the ch***is silver....and they swear it wasn't to try to make it look like aluminum.
    boy, is this off topic!
  14. kellym
    kellym
    from Menlo Park
    Thanks for all the replies, the team I'm working with has been participating in the FIRST events for over 10 years. We are currently using a Hobart 140 Mig, w/o a spool gun. We are generally welding 6061 series 1/8" wall, we are using .035 wire as we cannot push .030 wire through the machine without creating a birds nest.
    We prep the joints using a ss wire brush and pre-heat the joint with a propane torch, but our welds still look like ****.
    Squirrel, I'm with you, this summer we're going to build a frame out of thin wall steel tube this summer to show that it will be just as light or lighter than the aluminum frames we have been making.
  15. squirrel
    Don't expect the steel frame to be lighter than the aluminum frame...but do expect it to be easier to weld together. You need to manage weight well if you do this, we ended up with a 113 lb robot this year, because we knew we had to make the ball pickup, shooter, etc as light as possible.
    All the hep cats use TIG to build their ch***is with aluminum. Or if you want to get fancy, do it like 1501 (and 4183 my brother's team) and rivet sheet aluminum together.
  16. thepolecat
    thepolecat
    Here in my county (in Georgia) I used to sponser FIRST, BEST, FLL and F1 in Schools. We have been told that there will be NO welding happening even with flux-core **** because it is too dangerous. I have also been told (after having 3 nationally ranked teams at the middle school level in F1 in Schools, that the concepts are too difficult for kids)
    Needless to say, after 7 years teaching, I am done. This is my final year. I commend you for doing this and let me know if there is anything I can do to support you out there.
