where to find chrome lug nuts 55 pontiac
Discussion in 'The Hokey Ass Message Board' started by flyboys101, Apr 5, 2012.
  1. flyboys101
    flyboys101
    from nj
    Want to put some chrome lug nuts on my 1955 pontiac chieftain. Using the stock wheels and lugs. Can find some that are RH threaded but coming up zero for left hand threads on drivers side that match the RH lugs.
    Did a google search, summit racing, Kanter, etc. Nothing.
    Anyone have any thoughts?
  2. oldolds
    oldolds
    Try a good old parts house. They used to buy things like lug nuts and studs by the 50 pound box. Or you could change out the wheel studs, make everything rh.
  3. Mr48chev
    Old parts houses or really old tire stores that may still have some in the attic or back room.
    Still probably the simple solution is to knock the left hand studs out and put right hand thread studs in and be done with it.
  4. bobwop
    bobwop
    from Arley, AL
    NAPA. May not have them in stock, but will have them in a day or two.
  5. Stroker McGurk
    Stroker McGurk
    from Canada
    Change all your studs to RH thread....you will be glad you did in the long run
  6. inline 292
    inline 292
  7. flyboys101
    flyboys101
    from nj
    Thanks, these are perfect!
  8. Mule Farmer
    Mule Farmer
    from Holland MI
    got mine from the lugnut king. he even had Rh. and Lh. to fit the old et unilugs for a 56 poncho.
  9. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I'm sure that Ames sells the factory style chrome acorn lug nuts in LH thread that were used on '60-'68 8 lug wheels.
  10. dorf
    dorf
    from ohio
    funny i got mine at summit.
  11. no55mad
    no55mad
    They are in Calif, frequent many swap meets and they are great to deal with (Google lug nut king). Good deals on many wheel accesories including billet custom made wheel adapters.
