The dash is the guage?...thinking outside the box...
Discussion in 'The Hokey Ass Message Board' started by 3wLarry, Apr 8, 2012.
  1. 3wLarry
    3wLarry
    from Owasso, Ok
    ...just sittin' here trying to visualize a dash with no guage bezels and no gl***...just the needles sweeping across numbers painted on the dash...any ideas on how this would work?...how to mount them?
    yeah, I need a life...
    kidcampbell71 likes this.
  2. grits
    grits
    wow Larry, p*** that this way man :p
  3. ct1932ford
    ct1932ford
    What is in your Easter eggs:eek: Far Out Man:cool:
  4. Mr48chev
    Start with the biggest straight across speedometer from the mid/late 50's and go from there. Or use one out of a 57 Buick Roadmaster that has a red line that comes across and no needle and have the speedometer head behind a slot cut in the dash so all you see is the white/red line and your painted numbers.
  5. Doc.
    Doc.
    Even simpler yet...I had a FED with no gauges on it. The dash just had the words "Go Fast"
  6. EnragedHawk
    EnragedHawk
    from Waco, TX
    I'm not sure where you would start, but I'm digging that idea. I think that would look sweet.
  7. Hackerbilt
    Hackerbilt
    ...or paint a woodland scene on the dash and glue various Disney animals to the moving needles? :D:D:D :cool:
    Seriously though...some cool dashes DID use odd ways to get their point across. Wonder was there ever a thread on those odd dashes from over the years?
    Keep thinking on it Larry. You just might pull a rabbit outta that hat! ;)
  8. gasolinescream
    gasolinescream
    Remove the gl*** on the guage and extend the spindle holding the needle to your desired length. Smooth the dash, mount the guages behind the dash, poking the longer spindle through a small hole. Re-attatch needle, paint your numbers and good to go!
    But don't:cool:
  9. Von Rigg Fink
    Von Rigg Fink
    from Garage
    oops sorry i touched the dash on that last bump and bent all your needles:(
  10. No_Respect
    No_Respect
    from So-Cal
    My 63 galaxie wagon has no gauges at all I filled in the dash and now when I look down I see nice smooth metal no needles or gauges to distract me..
  11. Paul
    Paul
    Editor
    I've always? had a vision of a clean dash with only a clock right in the middle
  12. need louvers ?
    need louvers ?
    One of my bugs years ago had a dash that was just a bead rolled piece of aluminum with the headlight switch in the middle...
  13. rld14
    rld14
    This is a kick *** idea and I see no reason why it wouldn't work.
    Paint dials right on the dash, mount gauge to back of dash, stick needle on gauge sitting on surface of dash.
    I'd love to see someone do this.
  14. Farmer
    Farmer
    put the pipe down, the sweat ceremony is over
  15. Taff
    Taff
    where did you get your avatar?! she's my dream bikini girl!!
    er, where were we? no reason why it couldn't be done, but those needles would be vulnerable to damage.
    1959 Vauxhall cresta had a circular guage wuth no needle, just went from green thru amber to red as you got faster. you would just need to mount it behind your dash with a crescent-slot cut in your dash, and no needle to get damaged.
    getting off topic slightly, ever see a Citreon CX dash from the late 70's? Like a fruit machine, completely nuts
  16. tfeverfred
    tfeverfred
    Mount the guages behind the dash... flush. Take piece of plexi-gl*** (exact same size as dash panel) and rout out where the guage faces are. Then mount the plexi-gl*** in place. You'll have a flush dash and the needles will be protected.
  17. 3wLarry
    3wLarry
    from Owasso, Ok
    The only time I'd worry about hitting the needles is while cleaning the dash...and I rarely clean anything...
  18. Beau
    Beau
    My buddy plans to run no gauges. He is just going to glue an Earth magnet to a GPS unit and use that for speed. It's close.
    I like your idea though.
  19. Gofannon
    Gofannon
    If the Google Gl*** Project comes through you'll be able to transmit all of your gauge readings to your Google gl***es, no need for a dash at all (if someone writes an app for it).:cool:
    https://www.youtube.com/watch?v=9c6W4CCU9M4
  20. Uptown83
    Uptown83
    I was just thinking the same! I could easily see that in the future.
  21. 97
    97
    Right outside that " traditional square ".
    Just paint the dash a flat non reflective color , and project the "dash and guages" onto it like a fighter aircraft heads up display . For that matter project the heads up display right onto the windscreen and have nothing at all on the dash!! or have some sort of rear projection screen built into the dash .
    Not really on topic, but still possible !!
  22. Those movements and needles are so delicate they need to be protected.
    That's why all of them are behind gl***.
  23. :d:d:d
  24. Harms Way
    Harms Way
    That's it Larry !!!!,...
    Your not allowed to think any more today !... Now, Get back in your Box !!! :mad:;):D:D
  25. 3wLarry
    3wLarry
    from Owasso, Ok
    people laughed at orville and wilbur wright...:p
  26. Von Rigg Fink
    Von Rigg Fink
    from Garage
    why?...did they try this too?:D
  27. gnichols
    gnichols
    from Tampa, FL
    It sounds interesting, but you have to remember the gl*** is there to protect the needles!!! One errant swipe and you literally wipe out your gauges. Gary
  28. mikes35
    mikes35
    from texas
    I think Mikey Rooney did this in one of his old movies. He wrote the numbers on the dash wth chalk.gees I must be old
  29. silentpoet
    silentpoet
    from NWA
    and you could use a sun dial instead of a clock.
  30. ... and here I thought I was thinking outside the box by coming up with gauge lenses ground to my eyegl*** prescription!
