help identifying Lincoln transmission
Discussion in 'The Hokey Ass Message Board' started by Leyland, Apr 9, 2012.
  1. Leyland
    Leyland
    I'm looking for help identifying what year this lincoln transmission would be.
    40-41 (26 tooth gears)
    42-48 (25 tooth gears)
    49-51 (28 tooth gears)
    It was in a 1941 car, but the car had a 49-51 v8 motor, not the original V12... not sure if transmission was original or came from the 49-51 donor car?
  2. Bruce Lancaster
    Bruce Lancaster
    It is something in the '40-48 range for sure, so likely original to car. See if the serial # stamped near top of the trans bell casting, right above the little sheetmetal cover, matches the car's ***le. If not, there must be a list of Lincoln number ranges online.
    Post the first part of the number, first few characters with the H...quite likely that has a digit for year right in it.
  3. Leyland
    Leyland
    Hi Bruce,
    I will have to ask the fella to look for me and send me the #'s. I was hoping there was some obvious visual differences between the years but you are right, numbers always tell the tale.
    Thanks.
  4. Dale Fairfax
    Dale Fairfax
    Is the rear of the transmission set up for a torque tube or does it have a slip yoke? Torque tube is original Lincoln; slip yoke is '49-'50 Merc.
  5. Bruce Lancaster
    Bruce Lancaster
    Aha! Mac VanPelt has added the H motors to his serial number page:
    http://www.vanpeltsales.com/FH_web/flathead_serialnumbers.htm
    Torque tube hookup isn't in the pic, but the pic does show all sorts of Lincoln specific hardware, so I think it is going to Lincoln all the way back.
    There were some minor OD parts changes over the years, don't have the list handy, but I don't think there is any visual difference a****st the V12 side shifters...I wouldn't guess without looking at serial prefix.
  6. Leyland
    Leyland
    Great!
    I sent the owner an email, I will see what he finds for me.
  7. Leyland
    Leyland
    So the bellhousing reads 7HI6I962*
    Which falls under:
    1947 Lincoln V12 76H 7H-152,840 to 7H-174,289 (According to the website)
    Thanks for your help guys!
