Projects who know what about a 396
Discussion in 'The Hokey Ass Message Board' started by scharleyride, Apr 12, 2012.
  1. Just trying to find out what you think about a 396. I am looking for a motor for a 58 panel truck and came across a 1970 396 for what I think is a good price { $400.00 }. I don't have the numbers off the motor just going on what the guy is telling me, Plan to go friday night and look at it. O K get it. So as for a big block are they solid or do they have hidden problems. It has been on a motor stand sense the early 70's. so I'll have to go through it if nothing else to put new seals. So let me here what you think of a 396.
  2. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    The '70 396 (actually a 402c.i.) is a good motor. Depending on the heads, etc...
    They are a good running motor. It will do well for your project.
    Good Luck.
    VR&C.
  3. Deuces
    Deuces
    Yep! The 402 is just a 396 with a factory .030" over bore job... Still a great motor..
  4. squirrel
    condition is important, and we can't see it. First make sure it turns. I'd look over the numbers and see what it really is.
    But yeah, they're good engines, kind of heavy for how much power they make, but you can have fun with it. I swapped one into my 59 chevy pickup when I was 17, still have it, and I'm 50 now
  5. Ive got a 68SS396 Chevelle (I know, off topic) that Ive had 32 years, its got the stock bore and a Crane cam (Fireball) that still runs like crazy, I love the 396 engines!
  6. R. Seghi
    R. Seghi
    Oh, just buy it dude. A BB Chevy for $400? Buy it.
  7. GOSFAST
    GOSFAST
    Make sure you aren't getting a (tall-deck) 366" or 427" truck unit??
    Thanks, Gary in N.Y.
    P.S. Get ALL the casting numbers (block and both heads) before you shell out any cash and get back here with them!
  8. bobss396
    bobss396
    I'm partial to 'em. If you can get it with all the brackets, etc it's worth the $400.
    Bob
  9. That 402 with a 454 crank = 427!
  10. squirrel
    huh?
    how about the 402 crank in a 454 block + expensive pistons = 427
  11. Does it have hardened seats? .... either way well worth 400 ... and hope its all there appliances and brakets are pricey
  12. GassersGarage
    GassersGarage
    Great buy for the price. I found an abandoned 396, cast crank, pistons with oval port heads. The motor was frozen, so I beat the pistons out, honed the cylinders, re-ringed the pistons and added new bearings. Added a Sig Erson cam, dual plane manifold and an 800 Holley. That motor ran great in a '65 Chevelle.
  13. 1971BB427
    1971BB427
    from Oregon
    I think the 396 is the 2nd best BBC engine ever built! First being the 427 BBC. The 396 has plenty of torque, winds better than ome longer stroke BBC's, and in a 1970 should have the decent heads and a good compression ratio that will work on pump gas if it's the 325 hp version.
    Let us know what the engine and head numbers are!
  14. Mr48chev
    An absolute must with big block Chevys. Hit the sites that give casting numbers and print the big block numbers out so you have them in hand when you go look at the engine. It doesn't hurt to find a list of engine suffixes for those engines either.
    Print out a copy of this list down though the blocks and heads.
    http://www.nastyz28.com/bbcmenu.php
    Right now you don't give a rip about cast iron intakes or manifolds except for what you can sell them for and get some of the 400 back unless you want to run them.
    It's a must deal that you are able to tell what you are looking at so you don't get stuck with a 366 truck engine or pay more than you need to for an engine that is misrepresented be it intentionally or not.
    You can find a list of suffix codes here for 396 & 402 http://www.chevylegends.com/forum/archive/index.php/t-609.html
  15. Don's Hot Rods
    Don's Hot Rods
    from florida
    I used to run against a lot of 396 cars and except for the 325 hp base engine they ran like stink. The 396/425 hp Vettes were killers, and the 375 hp ones were excellent also.
    Don
  16. speakfordadead
    speakfordadead
    i wanna know what you guys have against tall decks??? Set up properly they are awesome pullers and have nice long carreers as haulers....... he is putting it in a truck... after all.
  17. gwarren007
    gwarren007
    IF I remember right the tall deck 366 and 427 had a lower compression (8:1 0r less), plus also has a 4th ring (compression). All of the rebuild parts are $$ more than the standard deck bbc's.`
  18. squirrel
    and it's a pain to find an intake or use spacers
  19. bobss396
    bobss396
    I have a '66 vintage 396/375 which is currently apart (spun bearing...). With the factory hi-rise manifold and the L88 solid lifter cam, its a runner.
    Bob
  20. I don't have to repeat all the good that has already been said.
    FWIW, I'll add this and it's important. If you have one bored oversize, and I don't mean just a .030" clean up bore, make real certain you use a very reputable machinist who has done them before. Here's why.
    The mains are fed from a oil galley coming down the side of the block along one of the pan rails. Then they branch off into each of the mains. When you get into the bigger oversize bore sizes, if someone isn't real sharp, they will break right into those oil galley p***ages going to the mains.
    I fix these blocks and guarantee them for the life of the block, not bragging at all, but most machinist don't know the correct procedure to do this and the block ends up tied to a boat serving duty as a anchor.
    Be very certain to remove all of the plugs to these oil p***ages if you have this block hot tanked or boiled in the future, very important.
    These engines are very very strong, and the 2 bolt main blocks easily convert to 4 bolt mains, much easier from a machinist standpoint than the small block. Duly noted though, it's not really needed to convert to 4 bolts except for real high torque numbers and or abuse, as once you hold one of these main caps in your hand and feel the heft and m*** of one you will know why.
  21. ardyboy
    ardyboy
    great engines--For $400 I would buy it and put it on the shelf with the rest of them. We used a stock 325 HP engine with 292 cam, aluminum dual plane intake and a 650 Holley in my sons Fiat altered. It went 10.7. Cool ride for a 17 year old.
  22. Bosco1956
    Bosco1956
    from Jokelahoma
    Same engine in both cars they just rated the Vette higher. 325hp version runs fine
  23. pasadenahotrod
    pasadenahotrod
    from Texas
    Thousands and thousands of SS396 Chevelles and Impalas say DO IT, DO IT!
  24. 38Chevy454
    38Chevy454
    A 427 is a 454 bore with a 396/402 stroke. Think of a 427 as an overbored 396, or a short stroke 454.
    427 compared to 454 BBC is kind of like the 302 or 327 compared to 350 SBC. Same bore but shorter stroke.
    A 454 crank in a 396 block would be a poor performance engine. Good for low end but not enough to beathe well on the top end due to smaller bore. Think of this as ****agous to the 305 SBC, similar small bore longer stroke.
    Back to the OP, the 402 you found sounds like a great choice for your truck.
  25. 396: Bore 4.094 Stroke 3.760
    402: 4.125 3.760
    427 4.250 3.760
    454 4.250 4.000
    A 402 is actually a 396 with a .031" overbore, not trying to be a wise ***, just the math for what it's worth.
    Stock length rod is 6.135" Hope that helps, TR
  26. tjet
    tjet
    Are 396 & 427 cranks the same?
    I'm planning on building a 427 for my vette, & I have my eye on a steel 396 crank. I've heard the counterweights are different. Thx
  27. 454 BBC, like the 400 SBC from the factory are EXTERNALLY balanced, TR
  28. Deuces
    Deuces
    I'd use it for a 427 build...;)
  29. pro 39
    pro 39
    from Michigan
    A 396/402 is a great engine. That is what I am currently running in my '39 . Vertex Mag, General Kinetics Cam,Glide with a Pro tree Brake... Runs pretty good!
  30. 1arock
    1arock
    No 396 and 427 cranks are not the same. They have the same stroke but, 427s have bigger counter weights. A 396 crank would need to be balanced to make a 427.
