U-Joint syncing questions...
Discussion in 'The Hokey Ass Message Board' started by metalshapes, Apr 11, 2012.
  1. metalshapes
    metalshapes
    I had to calculate this at school once, but thats a long time ago.
    So hopefully y'all can help me out.
    I know that if you have two U-Joints in a steering column with one, say, going 20 deg down and the other going 20 deg back up they need to be in sync.
    Because the rotational speed of the outgoing side is not constant through the whole revolution, compared with the ingoing side.
    The second U-joint distorts it back to zero, or even with the ingoing side.
    That much is clear to me...
    But if you have a U-Joint going down by, say again 20 deg, and the second also 20 deg going the same way?
    Do they still cancel each other out, or is the uneven-ness now twice as big?
    So do you still sync them as if the second goes back to zero deg?
    Or do you put them 90 deg out of sync to cancel out some of the uneven-ness?
  2. onlychevrolets
    onlychevrolets
    how fast do you plan of steering this thing?
  3. metalshapes
    metalshapes
    Its a Racecar.
    As fast as I can make it go... ;)
    Its more about precission than speed...
  4. squirrel
    I think the phasing has to do with the angular velocity, so it doesn't matte which way the joints bend...they need to be in phase so the changes in angular velocity happen at the same time at both ends.
  5. metalshapes
    metalshapes
    Cool...
    Thats what I thought it might be, but I wasn't able to visualise it.
    Thank you.
  6. metalshapes
    metalshapes
    Found the graph...
    It goes through a cycle every 180deg, so I think that means you are right.
    ( like there was any doubt...:D)
    They need to be synced.
  7. fordor41
    fordor41
    I doubt U-joint angle would matter in a steering set-up no matter what the angle. Case in point, my Windstar van has a terific angle under the dash and can't feel the
    velocity changes in the wheel.
  8. metalshapes
    metalshapes
    Thats true.
    In a Windstar it doesnt matter.
  9. RICH B
    RICH B
    May depend on the vehicle, we had some new Oshkosh plow trucks that had big angles in both planes in the steering shaft, found they had really strange feel during certain high speed maneuvering.
    Engineers revised the joint relationship so they were somewhat out of phase, don't remember how much; but the steering smoothed right out.
  10. metalshapes
    metalshapes
    All kidding aside, yes I think it does matter.
    Its a racecar, which means its going to get pushed to its limit.
    Having the same degrees of steering input at the R&P as you put in with the steeringwheel, at all times, is probably a good thing.
    Plus everything is ultra direct, and none of the components are rubbermounted.
    Right now it has the colum a bit too low.
    Its too close to the pedals and my feet.
    I dont want to use any chaindrives, bevelgears, or that kind of goofyness.
    But I can find the space I need with one extra U-Joint and a second support bearing on the column.
    Simple, light, and clean.
    But I wanted to make sure I wasnt about to make a mistake with my U-Joint syncing.
    I think I got the Info I need.
    Thanks again guys....
  11. mgtstumpy
    mgtstumpy
    Keep them in phase, simple.
  12. noboD
    noboD
    I'm with Squirrel on this one, angle matters not direction.
  13. fordor41
    fordor41
    My point is that in a normal situation, as a street car, You wouldn't know the difference. Sorry,Didn't realise you were referring to a race car.
  14. shinysideup
    shinysideup
    from ruskin, fl
    I'm confused how phasing relates to 3 joints? Can they all be in phase?
    If they are all curving around an object they wont cancel out. Canceling happens when one is "up" and the other is down the same degree.
  15. tb33anda3rd
    tb33anda3rd
    isn't that graph for a driveshaft? it would make sense that in a drive shaft the velocity would change as the suspension moves up and down. the steering is fixed [i doubt your mounting the rack on a straight axle] so the rpm would stay the same or am i missing something?
  16. noboD
    noboD
    No sir, the speed on the driven shaft is what changes. The other joint is what corrects the speed or phase. The more angle the more the speed changes. On a hard angle when you turn the u joint the driven shaft speeds up and slows down every revolution because of the differant pivot point on the trunnion. That's why CV joints are called constant velocity joints. The pivot radius is constant no matter what angle they are on. Hope this makes sense, it's pretty early to think.
  17. fordor41
    fordor41
    actually cancelling has nothing to do with the angle except for the amount of speed variation. The cancelling comes from how the U-joint halfs are positioned on the shaft in relation to each other (brg caps on each end in line). As one end's speed inc. the opposite end's speed dec. If both angles are equal, theoretically, the speeds at both ends of the shaft will be the same.
  18. tb33anda3rd
    tb33anda3rd
    thought about it all day, kinda get it, the difference in speed must be tiny. i would think the smaller the ujoint the smaller the difference? with the small ujoints used in steering, would you even notice?
  19. RICH B
    RICH B
    Went to a driveline seminar once, the rep had a training aid where you could reposition the the ends and vary the angle of the joints. At extreme angle you could see the shaft speed up and slow down, while the tachometers showed the input and output speeds matched.
    With three u-joints you need to actually look at it as two shafts, each one using the center
    joint.
    The speed changes are function of u-joint geometry not size. Big joints and little joints
    act the same.
  20. tb33anda3rd
    tb33anda3rd
    thanks, i'm not the sharpest bulb in the box so i'll have to think about that today too.
  21. noboD
    noboD
    I never understood it until I saw a very slow setup like RICHB describes.
  22. mrconcdid
    mrconcdid
    from Florida
    if you were using Double D shaft they would always be inphase, therefore Im sure they should be in phase, match up the steering box ( spline ) to be in phase with the other joints.
    To simple, maybe but it will work.
    Godspeed
    MrC.
  23. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    They still cancel each other out. Won't bind and will turn freely. It's easy to confuse driveline torsional vibration to joint-phasing.
  24. fordor41
    fordor41
    Yes, double joints are built in-phase but any added in line must be phased with the double joint
  25. fordor41
    fordor41
    Actually the joint speeds up 2 times per revolution, once for each cap.
