53 ford inline six-spin on oil filter-help
Discussion in 'The Hokey Ass Message Board' started by greasy53, Mar 28, 2012.
  1. greasy53
    greasy53
    Need some help trying to locate a new oil filter. The guy who had it before me put on a spin on type..not canister.
    Anyone have any idea what/where to get a new one to fit this engine? I took it to the local oil change place and they said they don't carry the filter...special order...
    Also, put 3inch lowering blocks on the stock rear leaf springs and it didn't lower the rear end....I'm thinking the shocks that are original are holding it up?
    Any suggestions?
    Thanks.
  2. greaseyknight
    greaseyknight
    from Burley WA
    Just get one for a later 223, 59 to 64 should work. Or if they still don't have it in the catalog, get one from a 75-96 302 equipped Ford truck.
  3. JohnEvans
    JohnEvans
    from Phoenix AZ
    Number on the old one? post it here. Lots of us have filter catalogs.
  4. Don's Hot Rods
    Don's Hot Rods
    from florida
    Shocks do not hold a car up, unless they are overload shocks with springs on them, or they are bottomed out and therefore solid with no movement.
    Don
  5. greasy53
    greasy53
    Ok, I looked on the filter and couldn't find any numbers so I took some pics to maybe help identify what would work on this engine.
    Please help!
    Thanks.
  6. Mr48chev
    Most of those adapters used a filter that fits the majority of Fords that use a spin on.
    Probably a NAPA gold Fil 1515 will work. You would have to take yours off and match the gasket diameter and threads on each to make sure though.
  7. Saxon
    Saxon
    from MN
  8. greasy53
    greasy53
    thanks for the leads...
  9. Diamond N
    Diamond N
    from Indiana
    You might want to check out the standard Ford/Motorcraft spin-on filter #FL-1A. Is recommended for 1957 and newer for most 6 cyl and V8s. I have installed the Ford/NH brand spin-on adapters on many early Ford tractors, back to 1953, and always run the genuine Ford FL-1A filters.
    Good Luck...
  10. forty1fordpickup
    forty1fordpickup
    I just put one on my '53 215' I bought the conversion kit from Joblot. It uses a Fram PH8A or Wix 51515
  11. green53ford
    green53ford
    from Wisconsin
    Check your rear shackles. I bet they got flipped over when you installed the lowering blocks. Thats what happened on mine.
  12. Chris F100
    Chris F100
    Wix 51515 on my 62 223
  13. greasy53
    greasy53
    thanks for the help....I will get the Fram tomorrow and get this thing done before viva this weekend...maybe I will see some of you guys there...
  14. dave lewis
    dave lewis
    from Nampa ID
    Please please please do NOT buy a fram filter...
  15. Willy301
    Willy301
    Please do not buy a FRAM filter, they are worthless....and they have blown off under pressure...
  16. Willy301
    Willy301
    And aren't you the one who posted about the lowering problem on another thread, did you flip your spring hangers?
  17. greasy53
    greasy53
    yea i tried all weekend and it didn't happen...i'm going to do it after viva this weekend...i got some other issues with those shackles too...bushings and other stuff...
  18. greasy53
    greasy53
    And the winner is...........Ford Motorcraft #FL-1A!
