276 hemi exaust bolt leaking water.
Discussion in 'The Hokey Ass Message Board' started by grock 31, Apr 16, 2012.
  1. grock 31
    grock 31
    from felton ca.
    Just got finished doing headgaskets and noticed an exaust leak.Pulled the bolts from the header and water started leaking from two of the bolt holes.Any ideas?
  2. lippy
    lippy
    from Ks
    Stud em and seal em. Lippy
  3. The bolts are into the water jacket - do like Lippy said and put some sealant on them an put them back in.
  4. The holes are tapped into the water jackets.
    Sealed studs, short set screw sealed and then bolts, seal the bolts and don't remove them with coolant.
    Plenty of ways to skin that cat.
  5. grock 31
    grock 31
    from felton ca.
    Thanks,its always nice when an easy fix comes through.
  6. bobss396
    bobss396
    Sureeeee.... just settin' you up to the next 6 problems that surface when you fix 1.
    Bob
  7. The biggest problems show up first
  8. George
    George
    Lower into water & upper into oil @ the top of the heads.
  9. grock 31
    grock 31
    from felton ca.
    Thanks for the info.
