Old Edsels never die, they just go to Sweden!
Discussion in 'The Hokey Ass Message Board' started by Mats W, Apr 8, 2012.
  1. Mats W
    Mats W
    Hi all!
    Maybe the ***le of the thread is al little provocative - but Scandinavia really is a significant market for old cars. Today there are approximately 500 Edsels in Sweden alone ;) This T-shirt says it all:
    :cool: :D
    Nedd som good advice regarding my ’59 9-seater Edsel Villager exported to Sweden from NC back in 2004.
    I bought this Station Wagon back in 2005 an drove it for two seasons, after that it has been sitting…
    On one hand the car is really nice; new paint and new upholstery – but on the other hand the ****** started to work really poor and eventually I got fed up and stashed the car away…
    The drive train consists of a ’69 Ford 429 bigblock with at C6 automatic ******. Unfortunately this install as far as I’m concerned is a real ”hack-job” :rolleyes: … The pictures speak for themselves:
    Oil is leaking from the front of the ****** :eek:
    The left parking brake wire is grinding the exhaust…
    The engine mounts
    Left side
    Left side – only one bolt :confused:
    Right side
    How the f*ck did this p*** inspection back in 2004?!?!
    ****** mount:
    1 (one) bolt :eek:
    And the ****** crossmember’s fastening in the frame:
    Do you guys think I'm I wrong regarding this as a true ”hack-job”?!?!
    I would much appreciate input how to go about in order to proper install this 429/C6 combo into my Edsel – THANKS :) !!
  2. OoltewahSpeedShop
    OoltewahSpeedShop
    My old Villager went to Sweden a few years ago. At first glance I was sure this was it. After seeing the hack pictures, it is a different car. Mine also had a BBF/C-6 combo, but was installed right.
    There's another white and red '59 floating around somewhere in Sweden.
    Your car looks like a few lined up bolts and some drilling would go a long way to getting things in order.
    Late '70's T-bird spindles and disk brakes are a bolt on deal that will give you 1" of drop built in.
    Good luck with it, I love these old Edsels.
  3. DRUGASM
    DRUGASM
    Ha, that's funny. I think M. Edell sold two to Swedes this last year, both 58Ranger hard tops. I think it's not too hack-ish but it definately needs some love.
  4. no55mad
    no55mad
    There is currently a nice 2dr HT on San Luis Obispo Calif CL.
  5. edsel.fi
    edsel.fi
    Cool wagon Mats ! Here in FINLAND, we have about 50 Edsels only.
    YOU have there in Sweden more money & more understanding for cl***ic rides :O)
    Quite thick spider web near mounts, I bet there was once black widow spiders.
    I found also 2 Black Widow spider nests from my "ELLI" edsel, luckily those were empty ones. Mika
  6. If you separate the motor from the ******, pull the torque converter off and there's a seal around the input shaft. Replace that and I bet your ****** leak goes away. I pulled the motor out of my 68 Cougar and put in back in and had the exact same leak. A days work for a $5 part.
  7. M.Edell
    M.Edell
    One Edsel went to the Netherlands and the other to Switzerland.
  8. The oil leak happen with time! you say the car sat for 5 years or so, that's probably why! Old cars don't like to sit. In the states that's called lot-rot! You're sure that the bolts just didn't rattle out and got lost over the few years you drove the car? It is a pretty nifty engine you got there! - and the brake cable! Oh well, it might fix it self when you bolt the engine in right! It's probably not as bad as it seem!
    Or! - you're right it's a hackjob!
    Klaus
  9. Mats W
    Mats W
    You've got a PM, Mika :cool:
  10. Mats W
    Mats W
    Thanks for your input, I'm just about to change that very seal this instant :)
  11. Mats W
    Mats W
    It started leaking before stored the car ... but otherwise you're quite right ;)
    And yeah - hackjob big time...
  12. Mats W
    Mats W
    UPDATE:
    While the ****** is out I thought I'd replace all gaskets and seals...
    Bought me a complete overhaul kit from Mr. Mechanic here in Sweden :)
    This is the progress so far - removing the valve body...
    // Mats
  13. olds79
    olds79
    Hi Mat
    do you have some good Adresses for Edsel Parts in Sweden? For technical and other things?
    Thanks
    Guido
  14. ClayMart
    ClayMart
    If it weren't for that spider web it probably would have come apart already! :eek:
    Don't remove the web until you get at least one more bolt in that engine mount. :D
  15. Stefan T
    Stefan T
    from Sweden
    Good luck with the ******
    I was and took a look today with the work
    /Stefan
  16. hotdamn
    hotdamn
    ill trade ya my 2 dr hard to for your hacked up wagon ;)
    seriously though, it ****s that it was half ***ed but at least its mainly pretty general fab work :)
  17. truckmen
    truckmen
    Really? :)
  18. greg
    greg
    Really a cool wagon. Mines a 9 p***enger. Mine had field rot, not lot rot.LOL
    I have to do all my work from the floor. That lift looks like a real handy tool.
  19. Mats W
    Mats W
    Hi Guido - PM sent :cool:
  20. Mats W
    Mats W
    HA HA!
    Good point!
  21. Mats W
    Mats W
  22. Mats W
    Mats W
    Thanks for your offer - but no thanks ;)
    Yeah, it isn't all that bad really - just pretty annoying it wasn't done right in the first place :rolleyes:
  23. Mats W
    Mats W
    Hi Greg, thanks for the props :cool: Mine is a 9-seater too, pretty rare stuff, right ? I read your thread and saw your crafts - looks good :)
    Yes I can recommend a lift for anyone with field rot ;)
  24. Mats W
    Mats W
    UPDATE:
    Progress as of today
    Will start dis***embling and cleaning of the Gear Train and Clutch ***y tomorrow :)
  25. greg
    greg
    Transmission work is that line I know not to cross. Wish I knew how to do it. It would save me some money for sure.
  26. Mats W
    Mats W
    There is always a first time ;)
    The reason for tearing the ****** to pieces is actually a mistake I made myself - when it first started leaking I poured ordinary Dexron oil in the car instead of Ford F-oil :eek: Hey, I'm the only Ford guy on my block and my other car fellas told me it was all right…
    So the ****** is only torn down for a good clean-up and while I’m at it I thought I might as well inspect it and replace the gaskets and seals. The only broken seal I know of is the one at the front pump :)
    Most likely I will learn some ****** stuff as I go along :cool:
    // Mats
  27. Stefan T
    Stefan T
    from Sweden
    I were and help him yeaterday and cleaned the valve housing
    /Stefan
  28. ratman
    ratman
    Sorry dude but if thats all thats wrong with a car of that age youve got nothing to ***** about.
  29. Stefan T
    Stefan T
    from Sweden
    Mats is working with the ******
    /Stefan
  30. mashed
    mashed
    from 4077th
    Believe me, that's not a hack job.
    It's simply mocked-up. Just a few problem areas to sort out, that's all.
