Customs Attn: TEXAS Gas tank needed to get home---> 1959 Ranchero
Discussion in 'The Hokey Ass Message Board' started by Tuck, Apr 16, 2012.
  1. stroked383
    stroked383
    from kilgore,tx
    I don't know your route but if ur close to kilgore I have tools and a somewhat clean s10 tank.
  2. bobss396
    bobss396
    You can always shore the tank in place with a wedged in piece of lumber or so... some tires as well.
    Bob
  3. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    hope you get things worked out buddy
  4. zman
    zman
    from Garner, NC
    BTTT for Tuck. Hope you get it worked out...
  5. 54stude
    54stude
    BTT. I would try the boat gas tank route also, and a few extra 5 gallon cans to hold gas. If you run out of gas in the 6 gallon boat tank, the primer bulb on the hose will help you re-prime the fuel line.
  6. dirt t
    dirt t
  7. hotrodjeep
    hotrodjeep
  8. injunjoes
    injunjoes
  9. Max Gearhead
    Max Gearhead
    from Wisconsin
  10. cvstl
    cvstl
    from StL MO
    Bump.... hope its working out.
    I'm ***uming it was you I saw heading south towing a project on I55 in IL. I was heading North to Chicagoland to pick up a sweet '35 Tudor project, so I only got a quick glimpse and was wishing I was going.
  11. Beau
    Beau
    FWIW, JB Weld USED to work, but will not work for more than a short period now days. Ethanol will eat it up pretty quick.
  12. TexasSpeed
    TexasSpeed
    from Texas
    Oooo, that ****s major. Hope you can get this resolved soon.. Bumping this back up!
    Nice to meet you at the show and party, by the way.
  13. GaryB
    GaryB
    from Reno,nv
    a bump for tuck
  14. lucky_1974
    lucky_1974
    Anyone have an update? Hope you are rollin' Tuck!
  15. ROADSTER1927
    ROADSTER1927
    Just for the record all metal body putty will work , if it can be dried out. Gary
  16. 327Eric
    327Eric
    may not help you right now, but you can buy a brand new tank from Speedway. I'd go the boat tank route to get home.
  17. pushrod_mike
    pushrod_mike
    from Austin TX
    Tuck if you need to get home you can take one of my cars and we can fix your ranchero before you come back next time.
  18. Oldmics
    Oldmics
  19. laloszephyr
    laloszephyr
    Your near or in Austin? Should be More the a few Hotrod, custom shops that are hamb friendly. Maybe one of them might be able to lend a hand,hint hint.
  20. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    UPDATE:
    OK heres what we did
    i s****ed the tank clean- and found fifty more holes on top
    i dont have pics cuzz my damn phone is broke
    but JoeTcreep took some pics and he can chime in later cuzz its funny-
    filled it full of water and sandblasted the scale off the top-
    then i bought all the jb weld they had at the store
    mixed it up like bondo and spread it on nice and thick
    let that cure out
    thenPOR'd the top of the tank-
    looks ***s............ :)
    leaving Texas today!!!
    gonna see if i can get a tank from bob on the way home!
    Thanks-
    Tuck
  21. Max Gearhead
    Max Gearhead
    from Wisconsin
  22. flatheadpete
    flatheadpete
    from Burton, MI
    Great news. Drive safe.
  23. Beau
    Beau
    The JB should get you home, but it'll leak again!
    I see you are picking up a tank though. Drive safe.
  24. general gow
    general gow
    MODERATOR
    look at you go, genius boy.
  25. Rudy J
    Rudy J
    Good seeing ya buddy. I will "Keep thinking kandy & flake, wont be fake, will buy a rake and keep it clean" hahaha
    Safe travels,
    Laters man
  26. JB weld orig formula will not leak and is completely gas proof.....
  27. yngrodder
    yngrodder
    If you have any troubles in my neck of the woods call me, i will check with a guy here to see if he has an extra tank if you want me to check,
  28. Beau
    Beau
    This used to be true. But not anymore.
    JB Quik won't hold at all. JB Weld will hold for a short while.
    Modern gas ruins it.
  29. yngrodder
    yngrodder
    Seals all in a yellow tube will stop a leak And you can actually put it on the leak while it is leaking and it will seal
  30. Dakota
    Dakota
    from Beulah, ND
    Going up 83 on the way Home past Flat Top Bobs?
    thats the way we went home.. hope its all good, that was some nice driving...
