Power valve question
Discussion in 'The Hokey Ass Message Board' started by 19Fordy, Apr 17, 2012.
  1. 19Fordy
    19Fordy
    According to the Holley web site you select the proper power valve by taking a vacuum reading at idle with a warmed up engine. Then subtract 2 from your vacuum reading and divide the result by 2. That will give you the correct power valve to use. I did that with my stock 8BA flathead. Vacuum reading at idle is 20. Subtarct 2 = 18. Divide 18 by 2 = 9.
    However, my Holley 390 carb came from Holley with a 6.5 power valve. Which power valve should I use? I bought an 8.5 but haven't installed it yet. Will an 8.5 power valve open sooner than the 6.5 valve? For some reason , I am having a mental block on this. Thanks.
  2. BigMikeC
    BigMikeC
    Yes an 8.5 will open sooner than the 6.5. I would put a 10.5 in it though. -Mike
  3. Blown 61
    Blown 61
  4. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Ill disagree with an 8.5 opening sooner It will open at 8.5 inches of va***n...Heres what I would do.Bolt on the holley and check va***n redings again,If its low go 2 incremates at a time 8.5 then 9.5 then ten,Youll get it dialed in better that way,Also buy a spring kit for a va***n advance........
  5. Blown 61
    Blown 61
    The valve will open when the vac drops below 8.5, that is why there is a spring on it, vac holds it shut.
  6. bobkatrods
    bobkatrods
    from aledo tx
    The way i have always done it,Is to hook up a vac gauge either tape it to windshield or if your hose is long enough put it inside the car.Drive the car and lay into the throttle at a steady rate, see what the vacuum drops to and choose your power valve with those figures.
