Can the Olds 350 be vintage cool????
Discussion in 'The Hokey Ass Message Board' started by MATACONCEPTS, Apr 18, 2012.
  1. MATACONCEPTS
    MATACONCEPTS
    Or maybe even the buick? **** any other readily available 70's 80's GM V8's. I guess the main part it the multi-carb intake.
  2. Don's Hot Rods
    Don's Hot Rods
    from florida
    There are dress up items that look old timey (finned valve covers, etc) but as you mentioned the intake situation is the hardest to overcome. Only intakes I know of are aluminum single 4 barrel. If there are multiple carb intakes I haven't seen them. Only solution might be something like a Vintage Speed 2 or 3 carb adapter.
    Good engines, just not a lot of hot rod type parts developed for them.
    Don
  3. Stevie Nash
    Stevie Nash
    I just sold my Olds project car that I had for years. Had 2 350 Olds engines with it. The only thing I could find was finned Edelbrock valve covers and a Offenhauser intake (4bbl). That's it....
  4. 34toddster
    34toddster
    from Missouri
    Same boat, a good 330 out of a 64 I'd like to build around!
  5. oldolds
    oldolds
    There are multi carb manifolds available. '66 '67 442 with a W option had 3 dueces on a 400. I think that was a small block motor. There were also some aftermarket 2X4 available.
  6. 49ratfink
    49ratfink
    no
  7. Mr48chev
    There is a shortage of dress up goodies for them but they run hell for good and they are dead nuts reliable. I think I've had six 350R's in various rigs in the past 40 years and have one stashed in the shed now.
  8. MATACONCEPTS
    MATACONCEPTS
    do these intakes fit 350olds???
  9. Stevie Nash
    Stevie Nash
    400 was a big block my friend.... wider intake.
  10. Don's Hot Rods
    Don's Hot Rods
    from florida
    Yep, 350 is different than 400 or 455. Even if you could find one of the very rare L69/W30 intakes (they only made something like 1200 of them in 66 and they go for BIG money) it won't fit your 350. Luckily, my Son did score one for his 455. :D
    Don
  11. MATACONCEPTS
    MATACONCEPTS
    That looks good. Vintage. 400 & 455 ah???? what years 60s & 70s? I now they make multi/carb intakes for those.
    distance from fan on pulley(no spacer) to CENTER of distributor????
  12. Don's Hot Rods
    Don's Hot Rods
    from florida
    I think the 455's started in 68 and went to 76. They are not high winders but make a ton of torque and hp up to about 5500. You can get 2 x 4 manifolds for them (but they are always on back order it seems) however they do show up on Ebay quite often. If my Son hadn't scored the tripower setup from his Brother he would have gone with the two fours.
    While a 455 wouldn't be traditional traditional, they can be dressed up to look pretty good. Everyone who sees my Sons likes it but they usually think it is a Cadillac motor or Pontiac. I guess that is because so few 400/455 Olds engines have trips on them.
    Don
  13. Phil1934
    Phil1934
    Offy has a dual quad
  14. Don's Hot Rods
    Don's Hot Rods
    from florida
    Yeah, they do, but they only make a run every year or so. We were having some sealing problems with my Sons tripower setup before we had it surfaced, and were thinking of ordering an Offy 2 x 4 manifold to get it on the road. No one had any and when I called Offy they said 10 months or so !:eek: Even Summit and all the other suppy houses were dry. Luckily, we found a race shop capable of machining the tripower intake to match the head angles, so we were able to get it to seal.
    Don
  15. Rusty O'Toole
    Rusty O'Toole
    Don't overlook the odd diesel version. It was based on the Olds 350 with mondo heavy duty parts, including heavy duty block, forged crankshaft and rods and other parts borrowed from the Super Duty 455. You could bolt on a 671 and never worry about blowing the motor.
  16. mike hohnstein
    mike hohnstein
    from wisconsin
    I like keeping them diesel, have 4 of them, two Olds and two Caddies.
  17. old soul
    old soul
    from oswego NY
    Any carbeated v8 is cool in my book. Better then using a deasil or some ****
  18. U-235
    U-235
    No !
  19. 56oldsDarrin
    56oldsDarrin
    It can be as cool as the 350 chevy can be if thats what you mean.....
  20. 390kid
    390kid
    yup
  21. 56oldsDarrin
    56oldsDarrin
    and there is NO rule that it HAS to be gold
  22. Oldskool27T
    Oldskool27T
    from Tyler,Tx.
    Check out my 27T album the engine is 350 Olds with vintage speed carb adapters.
  23. Swede64
    Swede64
    Offy finned valve covers are a nice addition. M/T finned covers are also available. The Olds 350 are way cooler than a Chevy 350.
