I need some ideas on gauges for a 1949 Mercury
Discussion in 'The Hokey Ass Message Board' started by bigbstang1969, Apr 18, 2012.
  1. bigbstang1969
    bigbstang1969
    Hello everybody, Im going to be converting my 1950 Mercury Coupe dash to a 1949 Mercury Dash. I really like the original Speedometer and clock and think Im going to keep those but change the fuel, oil, temp ect. Anybody have any recommendations for aftermarket gauges that maybe have a vintage or cl***ic look. Maybe some pics? Who knows, maybe Ill even convert the speedometer if I can find a complete setup that tickles my fancy. Thanks for your help and pics
  2. twochops
    twochops
    Here's how I changed mine.
    Use search here on H.A.M.B.(Up dated 49 Merc dash)
    TwoChops
    jkluge likes this.
  3. bigbstang1969
    bigbstang1969
    Twochops, What you did with the gauges looks incredible. Not sure if that can be topped. Thanks for posting.
  4. twochops
    twochops
    use search as posted in thread #2 ,TELLS HOW
    TC
  5. chaos10meter
    chaos10meter
    from PA.
    Cl***ic Instruments has some good looking gages.
  6. bigbstang1969
    bigbstang1969
    i did check it out, very nice way of doing it, as well as the Radio.
  7. chaos10meter
    chaos10meter
    from PA.
    Not real good photos but I had the upper dash pc. chromed and used white Dolphin gages which were too small for the original Merc gage holes, so I ground out the back of flush mounted closet door pulls to make like a smaller bezel to set the actual gages in and set these into the too large dash holes.
    ( I'm not real happy with the Dolphin gages, I wouldn't use them again)
  8. Vlopez22
    Vlopez22
  9. JJAGS3
    JJAGS3
    I need a good working temperature gauge for my 51 Mercury, if you are going to sell your old gauges. JJags3@aol.com
  10. HOLLYWOOD GRAHAM
    HOLLYWOOD GRAHAM
    from Ojai,Ca
    Old S/W’s but lighting is a little dim on mine.
