Little heavy on the go pedal....
Discussion in 'The Hokey Ass Message Board' started by gearsforguts, Apr 20, 2012.
  1. gearsforguts
    gearsforguts
    from temple,pa
    Doing a little showing off got me this.
  2. garcoal
    garcoal
    seemslike a perfect time for a upgrade on the driveline
  3. shinysideup
    shinysideup
    from ruskin, fl
  4. BIG-JIM
    BIG-JIM
    from CT
    looks like you found a weak spot.:D
  5. gearsforguts
    gearsforguts
    from temple,pa
    Its the 5th one lunched ,down to my last spare. time for a upgrade is right haha
  6. mrconcdid
    mrconcdid
    from Florida
    Ouch, shim the axle to spiders and weld them together and make it a spool
    Godspeed
    MrC.
  7. JB weld and your good to go.
  8. gearsforguts
    gearsforguts
    from temple,pa
    Yeah I've found out the 55-64 chevy rears are weak.5 pumkin's and one broken axle in the past 14 years i'snt to bad i guess.
  9. tommyd
    tommyd
    from South Indy
    Breakin' stuff is....cool!
  10. tims37chevy
    tims37chevy
    from Minnesota
    Your name fits you "gearsforguts"
  11. Acme Speed Shop
    Acme Speed Shop
    MODERATOR
    from so cal
    "toofless"
  12. coolbreeze1340
    coolbreeze1340
    from Indiana
  13. 49ratfink
    49ratfink
    I say drill holes in them and make a necklace and matching ear rings for the ladies
  14. Relic Stew
    Relic Stew
    from Wisconsin
    One with 4 spider gears.
    A 2 spider 9" will just do the same thing.
    Some type of limited slip or locker would be a good idea. The one-wheel burnouts overload the spider gears.
  15. BrandonB
    BrandonB
    from nor cal
    Looks like you lost all your wisdom teeth.:eek::eek::rolleyes:
  16. gearsforguts
    gearsforguts
    from temple,pa
    It never really smoked the tires,just hooked and took off. Until the ring and pinion or spiders let loose. Yeah well these things happen. Already got the spare pumpkin in,just gonna have to keep my foot out of it till i find a rear that'll hold up better.
  17. f.i.57chevynut
    f.i.57chevynut
    Looks like you just need a posi to prevent the breakage. The stock posi is 4 pinion and has no slop if it has Belleville plates.
  18. CAMSHAFT666
    CAMSHAFT666
    My brother has a 62 Impala with a 468 in it and he has the factory rear end in it. He keeps a few extra third members around too...
    I think hes on number four, so i broke down and gave him my 9" out pf a galaxy! Next winter project...
  19. 49ratfink
    49ratfink
    what 2 words are ALWAYS spoken right before a 55-64 pumkin explodes?
    "Watch this!"
  20. I would have upgraded after # 2, :) no way the third one would have been the same.
  21. ClayMart
    ClayMart
    Three words: "Hold my beer!"
    Maybe it just needs less tire? ;)
  22. daddio211
    daddio211
    Maybe Dr. Dave can fix ya up!
  23. Muttley
    Muttley
  24. graham_paige
    graham_paige
    from Australia
    Your mum always wanted you to be dentist didn't she....
  25. LOST ANGEL
    LOST ANGEL
    Looks like an easy fix, to me!-MIKE:D
  26. bobss396
    bobss396
    Oh yeah, they pop like penny candy in the stock form when put to abuse. Especially if they haven't been gone through in decades.
    Bob
  27. bobss396
    bobss396
    That was my initial thought... although welding 90-weight makes me queasy at times.
    Bob
  28. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I think I would check if the rear end were warped slightly
  29. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    I had an '09 in a '62 Impala in the 70's that would do that. After I was told that both wheels were wobbling I pulled the axles and both had about a half round of twist. Than car kept me broke buying ******s and diffs
  30. gearsforguts
    gearsforguts
    from temple,pa
    I run a 275/60/15 on the back.
