1946 ford front sway bar
Discussion in 'The Hokey Ass Message Board' started by ml68nova, Apr 23, 2012.
  1. ml68nova
    ml68nova
    Im looking into hooking up my front swaybar. The bar and suspension are factory except for the perch pins the sway bar links to. I`m using the C and E smooth top perch pins.
    The orig perch pins are hard to find and they arent repopped. I have a rear C and E sway bar already on. I talked to them awhile ago (2 yrs or so) and they didnt make one for the factory suspension.
    What have others done for the 46-48 fords? Is there a thicker bar I can use from another car?
    Ive been advised not to weld on the perch pin or the wishbone arm. So for right now im thinking of adapting links from a 99 altima and a aftermarket suspension type clamp.
    Im getting the car ready for some dragracing this summer and was told the top heavy cars like mine can be a handful top end.
    Thanks, Mark
  2. Don's Hot Rods
    Don's Hot Rods
    from florida
    I'm not following one part of what you are saying. Could you use original 46-48 perch pins if you could find them, or will they not work with your setup for some reason ?
    Don
  3. Just some ideas.
    Stock perch bolts show up quite often on that auction sight at reasonable prices.
    I don't know feasible it would be; but could you remount the bar a little forward and use the Chassis Eng "peanut" brackets on the bottom of the axle.
    I used a thicker front bar from www.weedetrstreetrod.com (weedburner 40 0n the HAMB).
    I am using a 40 Fort dropped front crossmember so I had to make some custom axle mounts. I think the heavier bar will work better with the Chassis Eng rear bar I am using.
  4. ml68nova
    ml68nova
    Don:
    I would like a heavier bar, but if I could find the orig style perch pins i would go with them to save on costs. I`ve just started thinking about this again. I tried 2 yrs ago to find some, but nothing came up on ebay. When something did it was for only one.
    Rich:
    I sent an email to weedsterstreetrod asking about the bar and links. I might go that route.
  5. 48FordFanatic
    48FordFanatic
    from Maine
    I have parts left over from my 48 coupe ( Installed a MII ) . What exactly are the perch pins? If I have them you are welcome to them. John
  6. 343w
    343w
    I have a complete 46 frontend, I'll take a look to see what it has for swaybar setup and let you know. The stuff you're looking for shouldn't be that hard to find.
  7. ml68nova
    ml68nova
    These are the bolts I`m looking for.
  8. 48FordFanatic
    48FordFanatic
    from Maine
    Sorry, don't have them. John
  9. Hnstray
    Hnstray
    from Quincy, IL
    I used a 90's Jeep Cherokee (not Grand Cherokee) anti roll bar on my '47 Ford Coupe build. Width is good and it is much stiffer than the the stocker. The front mounts I attached to angle brackets which bolted on using the same bolt/holes for the front bumper brackets. At the rear I used the Jeep links by fabricaing a small bracket for that purpose. Readily available used for very little money.
    Ray
  10. buddy graham
    buddy graham
    from irving tx.
    I got 2 stock perch pins from someone out of n. California. Can't thing of the name . Bob drake associate told me about them
  11. ml68nova
    ml68nova
    Thanks for the replies! I was able to bolt up my factory swaybar using my idea of nissan ultima links, leaf spring clamps and welded up brackets. works pretty good.
    My neighbor has a jeep cherokee going for scrap so he gave me the front swaybar. The width was good like Hnstray said, but the curved up ends would have interfered with my C&E shock kit. if they were straight it would have worked fine. But at least I have something to base ideas on now when I do go for something beefier. Thanks!
