1939 dodge Coupe
Discussion in 'The Hokey Ass Message Board' started by Peterson32, Apr 23, 2012.
  1. Peterson32
    Peterson32
    Hey everyone thought it was about time i started a thread
    I purchased this old Dodge from a co-worker here at the speed shop,
    last Round up 2011. as the months past i would work on it in my spare time after hours.
    motor was locked up ,transmission was stuck, and the rear end had a Chevy rear bolted in just enough for it to roll around
    here are pictures to catch you up
    i have gotten a lot done the past couple months so if you have any questions feel free to ask
    first start was reattaching all the body panels that were taken off hood,hood sides, grill, bumpers,
  2. Peterson32
    Peterson32
    so i wanted to see if i could get the motor running soaked the cylinders with marvel for about a week or 2 i was able to get the pistons freed up in the cylinders but had no compression. i pulled the head and all the valves were froze up
    Bob Bleed was telling me you could soak the valves with oil and slowly taping them down with a small hammer a little bit at a time would eventually free them up. for about 2 weeks during my lunch break id go out there and soak the valves with which ever penetrating oil i could find.
    Finally go them all working i cleaned the head and top of the block really well replaced the head gasket and found a cheap swap meet carb i replaced the points, plugs, wires, coil , cap, rotor, hoses etc.. after a few attempts it fired right up and smoked filled the shop!!
    i couldn't believe how well it ran!!! sounds awesome ill post a video later
    changed over to the Artillery wheels
    next was brakes i found it very hard to find brake parts for these early dodges without spending a bunch of money
    a local guy in my neighborhood was parting out this old 36 dodge on craigslist
    so i was able to buy the rear end / drive shaft, the complete front end with fairly new brake parts, also scored another Flathead 6 and 3 speed floor shift trans, also gas tank as mine was Swiss cheese
    THANKS MARTY!!!
    this was a big help i could tell there was a few differences in the brakes but i was able to use the brake hoses and wheel cylinders springs /clips i had my brake shoes relined and the drums turned the bearings and races looked great so i cleaned them up really good and repacked them and re***embled.
    the rear end was a bit narrower so i moved the perches over to fit in the stock location of a 39 rear 36 rear i believe was about 1 3/4 narrower
    as for the trans i removed the column shift transmission and swapped in the floor shift and it was a direct swap minus the emergency brake connections the drive shaft fit perfect and was now back together with the correct parts
  3. 1951Streamliner
    1951Streamliner
    from Reno, NV
    Looks like a great start!
    As always, I put my vote in for a traditional mild 40s- early 50s custom.
    I love pre-war coupes!!!!
  4. Peterson32
    Peterson32
    as for the floors they were completely rotted out so Bob Bleed convinced me to channel 5 inches it as i was starting over on the floors anyways
    so it begins!
    starting out with what looks like a 4x4
  5. Jonnie King
    Jonnie King
    from St. Louis
    Good start on a RARE rod. Keep up the thread with progress updates. These are truly awesome machines...and are not "common" so they're much cooler when finished.
    "RARE" IS GOOD !!
    Jonnie www.legends.thewwbc.net
  6. Peterson32
    Peterson32
    still sat up high in the rear so i put some 3inch blocks
  7. Nice start, great looking car!
  8. hfracing53
    hfracing53
    Good job ! Keep up the good work . Glad to see someone building some prewar Mopar tin . And keeping it all Mopar too ! Also good to hear you got them stuck vavles to come loose . They can take alot of patience sometimes .
    Good luck with your project . Later , Scotty
  9. Damn love 39-41 Dodge/Plym coupes....what's gonna power her? Pls say the Dodge FH 6 !!
    farmer12 likes this.
  10. 1951Streamliner
    1951Streamliner
    from Reno, NV
    Looking great!!!!!!!
    That car has a perfect profile
  11. MR. FORD
    MR. FORD
    from Austin, TX
    Looking good Jeff! I always thought that car could be awesome.
  12. Weasel
    Weasel
    Love the Deco Dodge - would like to see stock lights both front and rear....
  13. Peterson32
    Peterson32
    i like the stock rear taillights!
    as for the front im having a really hard time finding a pair of stock bezels/lenses
    and yes im keeping the flathead 6 in it
  14. 60galaxieJJ
    60galaxieJJ
    That's one hell of a good looking coupe!
  15. RAF
    RAF
    from MA.
    Great work!! Really like the look.
  16. ntxcustoms
    ntxcustoms
    from dfw
    Hey man good work so far! I'm working on a 39 dodge coupe to and it's IMPOSSIBLE to find parts. I need tail lights and the only one I see is on Egay for around 300. Also the PO removed all the freakin side trim so I'm looking for those pieces to. I'm keeping my suspension stock but decided to run a 318 and a rack for steering. Change your front shock mounts for obvious reasons...it will make a world of difference. I plan on channeling mine to as my floor is completely gone. Keep us posted.
  17. striper
    striper
    What a great looking car. Love the already chopped roofline.
  18. Stevie Nash
    Stevie Nash
    Parts are going to be hard to find! Especially that speedo...
  19. tjmercury
    tjmercury
    I love it! Another old MoPaR getting saved! Good luck
  20. rrbrucea
    rrbrucea
    Love what you're doing on this, nice work!
  21. skooch
    skooch
    Great Save! Looks really good. Great looking 55 stude in the first picks too.
  22. duke7427
    duke7427
    from Colorado
    subscribed. awesome
  23. 70kid
    70kid
    from Denver
    very very sweet!
  24. Peterson32
    Peterson32
    Post a picture of yours id like to see it!
  25. Mopar Jack
    Mopar Jack
    Sweet....MOPAR are no car...
  26. Peterson32
    Peterson32
    went to Pate swap meet at the speedway in Dallas couple of weeks ago, i scored original bezels and lenses for the dodge !!!! i couldn't believe it only paid 5 bucks each for the lenses also 39 ford headlights and bezels which i plan on using as well
  27. James D
    James D
    Cool project!
  28. go-twichy
    go-twichy
    what a great feeling to have it start after soaking it for weeks. nothing better, see how it begins? just something to work on, play with. soon it will take over. have fun.
  29. sololobo
    sololobo
    My MoPar freak flag is flying!! Man did Chrysler know how to styelize their rides with great body reveals and swoopy lines. The front bumper with those sweet overriders is smooth. The wheel change up is perfect and Bleeds guidence on the body drop is super cool. Very cool the old flatty is running some twice straight pipes should make that ol girl humm. Always great to see machines from the worlds coolest shop get back on the road! ~sololobo~
  30. Dodgy39Coupe
    Dodgy39Coupe
    Nice looking car. Very different to the 39 Coupe Ozzie version I have got. Keep up the good work as it will look awesome when completed.
    Thanks for posting photos of it as a work in progress. Inspiring stuff.
    Unfortunately mine is missing a fair bit of the trim and bumpers which you have got but I agree that dash is going to be a bit of a challenge.
