Projects '36DD - (My Double Duty 3-window build.)
Discussion in 'The Hokey Ass Message Board' started by Surf City, Mar 30, 2012.
  1. Mart
    Mart
    Post above reported.
  2. 1938ute
    1938ute
    from australia
    nice work bear,subscribed.
    Cheers Steve.
  3. Surf City
    Surf City
    Thanks Steve - I'll try to keep them coming.
    Bear:)
  4. richie rebel
    richie rebel
    as always nice work bear,looks like you tig also, looking good.....richie....
  5. TexasSpeed
    TexasSpeed
    from Texas
    Looks great! Hopefully modifying my front end will come close to being as nice as yours are. :)
  6. Fomocokid
    Fomocokid
    from Rapid City
    very clean work. Keep it up
  7. Surf City
    Surf City
    Thanks, Richie
    Let's say I 'try' to tig.
    Sadly, i just don't get enough hands on time to get real good at it - I'm a signwriter by day, and as much as I try to get out in the shop at night, I've been so busy with work lately I find that I'm just too stuffed to really make much progress on the coupe, let alone practice getting 'pretty' welds.:(
    Still, I figure from where I am at, it can only get better...:eek:
    Bear:)
  8. Surf City
    Surf City
    Cheers, Kellan.
    I've been watching your build with awe for quite some time!
    Very inspiring.:)
    I may need to get some pointers off of you when I get to the bodywork stage...:cool:
    Bear:)
  9. Surf City
    Surf City
    I got one of the So-Cal repro 'vette style bellhousings to mount my Tremec up to the 327.
    Once I had the two bolted together, I set them in to place in a position where I wouldn't have to mess with the firewall, and where I would have a good 4 1/2 inches pan to ground clearance at ride height.
    I wanted to run a Hurst type mount in this, but obviously a genuine one wasn't going to cut it with the ultra low frame height, so I set about designing one of my own.
    Here's what I came up with.
    Once I was happy with the look, I re-drew it in my sign-making program, cut a template in sign vinyl to double check the fit, and then sent out a file to our local profile cutter to get the plate cut.
    Bear:)
  10. richie rebel
    richie rebel
    1,500 bucks for the bell housing...whoa........
  11. richie rebel
    richie rebel
    never mind was looking upside down
  12. Surf City
    Surf City
    Once the main plate came back from the profile cutter, I drilled the mounting holes and cut a section of strap to use for the horizontal piece.
    Bent it up carefully by hand in the vice to match the bottom profile of the main plate.
    Tacked the two pieces together and set them in place...
    Then set the block in to position.
    Real pleased with how the mount flows with the angle of the front crossmember...:D
    ..but who the hell is ever gonna' see that!:rolleyes:
    Bear:)
  13. knotttty
    knotttty
    looking great... it does flow well... I have been following your build.. and I am totally impressed... great work... I look forward to your updates...
    Roy
  14. TexasSpeed
    TexasSpeed
    from Texas
  15. Surf City
    Surf City
    Cheers, guys.
    More updates coming soon:)
  16. 60'coupe
    60'coupe
    This is a well thought out build ! Great work.
    60'
  17. kippers 34
    kippers 34
    Excellant workmanship. Great eye on the details.
  18. n.z.rodder
    n.z.rodder
    You'll be doing this on all the posts, may pay to wait till the end of the build.:cool:
    Scotty.
  19. ironandsteele
    ironandsteele
    One of my all time favorite cars. Love it dude
  20. HUH? I see the spam was deleted but what's this post mean?:eek:
  21. Surf City
    Surf City
    Yeah, can't work this one out either?
    Spam post has been removed already. :)
  22. Surf City
    Surf City
    Thanks again for the encouragement, guys.
    Made a rear gearbox mounting out of a fabricated channel.
    I cut the topside down to fit around a standard turbo 350 type mount.
    Then I welded it all back together, capped the ends to allow it to bolt into the x-member, and drilled a couple large holes to continue the 'stock' Ford theme.
    Bolted into place, awaiting a rubber mount.
    Bear:)
  23. jfrolka
    jfrolka
  24. 32rick36
    32rick36
    Looking Good! And don't fret over the six yrs I have had mine sitting around since 1974. Keep the updates coming.
  25. Surf City
    Surf City
    I'm not so much bothered about the 6 years it sat before I got started on it - more the fact it's taking so long to make any real progress now.
    There always seems to be something gets in the way. Just spent the last month moving my folks out of their home and into a retirement village -haven't been anywhere near the coupe.:(
    The way things are going, I could be on mine for forty years too...:rolleyes:
    Bear:)
  26. woodbox
    woodbox
    Six years is nothing to worry about. I took my finished ch***is to the blaster's today after 8years of work. I have about 76 days to finish it for a show we are holding!!!!!
    Your ch***is is looking spectacular!
  27. 1938ute
    1938ute
    from australia
    My 38 ute has been in the build process for about 16 years and i have owned it for near 20 years. Life and other projects get in the way?
    Cheers Steve.
  28. Surf City
    Surf City
    Yours is looking pretty damn good too!
    Ain't it amazing how much you can achieve when you're on a deadline:D - I think my bucket floundered for around 5 years till I entered an event with it, then I did around 90% of the work in the last month.
    Sometimes we just need a bit of a push (or the fear of public ridicule);)
  29. Looks great Bear! Keep up the awesome work!
  30. OBFB HA/GR
    OBFB HA/GR
    Just a Sign Painter you say. As usual your perfect eye for detail and style shows through. Good build tread mate. Nigel.
