Features 250 INLINE 6 "lets see em"
Discussion in 'The Hokey Ass Message Board' started by roosters hot rods, Feb 10, 2008.
  1. 63ChevyII
    63ChevyII
  2. Marty Strode
    Marty Strode
    This my 250 (bored to 266), in my dragster, note the rare "IFFO" valve cover!
    kiwijeff likes this.
  3. Twisted6
    Twisted6
    Nice ride.Who did your header work?
  4. Marty Strode
    Marty Strode
    Here are two more views of the car, I built the headers along with the rest of the car. Now if I can just get it finished.
  5. 64-4door
    64-4door
    from Minnesota
    Bad picture but just picked it up Sunday. Replacing my old 230 in the Belair ;)
  6. imopie
    imopie
    Inlines rule! I scored a 250 for free and I'm equipping it with 3 carbs and custom headers. Backing it up with a 200r4.
  7. Twisted6
    Twisted6
    Great job on all of it,I'm sure it will be a blast to drive.
  8. 63ChevyII
    63ChevyII
  9. RainierHooker
    RainierHooker
    from Tacoma, WA
    250 that's getting ready to be put in the Chevy II wagon. Just needs a little more work 'n clean-up...
  10. RainierHooker
    RainierHooker
    from Tacoma, WA
    Dropped the motor in tonight. Just gotta hook up all the peripherals, fill it up with all oil and coolant, and (fingers-crossed) everything springs to life...
  11. 64-4door
    64-4door
    from Minnesota
  12. 64-4door
    64-4door
    from Minnesota
    Cleaned up my 250 and added a chrome air filter housing ;)
  13. 63ChevyII
    63ChevyII
    down the drivers side and over the rear end. at that point, the p***enger side crosses over to the over side of the car.
    I will probably end up redoing it. The routing is good, but the shop did a horrible job on the welds. I can't afford to pay someone to redo it, so I'll probably try to do it myself.
  14. 64-4door
    64-4door
    from Minnesota
    okay, quick question for all my 250 guys here. My mill has three holes in the valve cover, one for the breather, one on the back end of the top for vacuum leading to the carb. but the other one leads nowhere, and I cant find anything on the web that talks about it. I dont know what it's called, although it can be seen in the image i posted above.
    Also, ***uming it is another vacuum port, would I be able to use that for the vacuum on my th350 or carb? Thanks gang.
  15. RainierHooker
    RainierHooker
    from Tacoma, WA
    The three port valve covers are late 60's-80's covers.
    Upper Rear: PCV valve - hose to manifold vacuum
    Upper Front: Oil cap - Non-Breather type
    Side Front: Breather - Hose to Air-Cleaner
    When I put my 250 in my Chevy II, I swapped to an earlier two-hole valve cover (they aren't reproduced, so you have to find an original one) with a breather-type oil cap in the upper-forward hole. Works good, lasts long time...
  16. Twisted6
    Twisted6
    That went to the stock air cleaner.It is the oil breather That is mounted on the inside of the air cleaner. You can USE a exspandable freeze plug and block it off.And do away with the hose just hanging there. hope this helps.
  17. 64-4door
    64-4door
    from Minnesota
    Almost ready to be swapped in ;-)
  18. wheels777
    wheels777
    from York, PA
    This is a great thread!!!
  19. The_Monster
    The_Monster
    Anyone in the Oregon-Washington area have a runner they want to get rid of????
  20. olkarz
    olkarz
    That's HOT!!! I have a couple of these superchargers in my garage.
  21. 64-4door
    64-4door
    from Minnesota
    <object width="400" height="224" ><param name="allowfullscreen" value="true" /><param name="movie" value="http://www.facebook.com/v/4024708057674" /><embed src="http://www.facebook.com/v/4024708057674" type="application/x-shockwave-flash" allowfullscreen="true" width="400" height="224"></embed></object>
  22. Twisted6
    Twisted6
  23. 63ChevyII
    63ChevyII
  24. leaded
    leaded
    from Norway
    mine......50 Fleetline
  25. Little Terry
    Little Terry
    Does anyone know if a small block v8 flywheel and clutch will fit a 250/292 L6.
    It's hard to find inline parts in the uk!
    Thanks,
    Mark.
  26. Twisted6
    Twisted6
    YES but you would have to redrill for the 292
  27. Little Terry
    Little Terry
    Thanks Twisted6. So the 292 is a different bolt pattern to the 250???
  28. Normbc9
    Normbc9
    Here is a 250 inlline Chevy using a larger crank and cam.
    Normbc9
  29. Twisted6
    Twisted6
    Same patteren But some 292's had 1/2 bolts and 3 pins
  30. 1970nova250
    1970nova250
    hey guys
    im brand new here im wondering about a heat plate for headers ,
    i live in florida and im driving a nova, so the engine is fully enclosed do i really need this heat plate and so on for it to run headers on my 250. id rather not drill or anything any help would be fantastic.
    thanks!
