41 Tudor, replace the starter
Discussion in 'The Hokey Ass Message Board' started by sic41, Apr 26, 2012.
  1. sic41
    sic41
    I have a 41 tudor and need to replace the starter I'm not a dummy but I can't see how to take the old starter off to replace it. Any and all help would be apreciated.[​IMG]
  2. 1941coupe
    1941coupe
    the two bolt that p*** through the starter are long and tread into the housing ,have 1 or 2 5/16 course nuts handy when you remove starter as tthese bolts hold the starter togeher ,,
  3. sic41
    sic41
    thanks for the info , I'm off to do some parts changing.
  4. sic41
    sic41
    Got old starter out quickly , new starter doesn't want to go past flywheel they are different in appearance , Catalog said the one I got was the right one? [/ATTACH][/ATTACH]<!-- / message --><!-- attachments -->
  5. alchemy
    alchemy
    Flatty starters need to be tilted and swung to the side a bit on installation or removal. If you have headers in the way sometimes it can be tricky. Just wiggle it a round a bit and it should go. As you can see, you need to get the big drive around the side of the ring gear in the tight confines of the pan.
  6. sic41
    sic41
    I got the new starter in,Thank you for the help folks. I didn't have to file or grind anything!!!
