Can My Hemi Be Fixed ????
Discussion in 'The Hokey Ass Message Board' started by Camm, Apr 26, 2012.
  1. Camm
    Camm
    Broke a lifter bore. Can this be welded and will it work ? I have the pieces to put it back together.I would like to find a shop in Nor Cal or Oregon to fix it. Thanks:confused:
  2. czuch
    czuch
    from vail az
    Almost anything can be fixed. I'll bet someone here has done it.
  3. I haven't done it but if it were my block I would surley be trying to fix it unless I had a line on another.
    it is going to invlove being welded and bored, perhaps bored and sleeved. You will have to index off of another lifter bore to get your spacing correct. Correct spacing is critical.
  4. bangngears
    bangngears
    from ofallon mo
    i dont think that can be fixed.Never heard of a save that involved.
  5. Heo2
    Heo2
    I saved a lifterbore on a race harley one time
    silver solder it if i remember corectly
    Dont remember though how it was constructed on that engine
  6. RichFox
    RichFox
    I have seen aluminum blocks reparied when that happened. I guess an iron block can be repaired. Might not be cheap.
  7. Heo2
    Heo2
    That one o would bore out and sleeve with a sleeve
    thick enough to hold up and solder the sleeve to
    the block and dont weld the piece back
    if you have to farm it out i doubt its cheaper than
    finding a new block
  8. shawnspeed
    shawnspeed
    from Attica Mi
    I would counter bore it & put in a bronze bush....Just me ...Shawn
  9. 73RR
    73RR
    Camm, that is kinda what I was afraid your pic would look like...:(
    If you think you want to fix it I'd recommend installing a press fit sleeve with at least a 1/8" wall thickness. Don't forget that you also have to have a window to intersect the oil galley.
    I may have found a main cap for you but I think the lifter bore repair will be expensive.
  10. toddc
    toddc
    I agree with 73RR. Bore and sleeve.
  11. Camm
    Camm
    Thanks for all the input, more would be great.
  12. brigrat
    brigrat
    from Wa.St.
    I would "V" it out on the outside, install an old lifter in the hole for centering, weld up, ream out install sleeve with what 73RR recomended for galley hole....................................
  13. Shaggy
    Shaggy
    from Sultan, WA
    Block off one side of the motor, pull off all the rods and pistons from that side and make it a 4 banger if all else fails!!
  14. Nethery
    Nethery
    from Palm Coast
    Forget about welding the broken piece back on. Like mentioned above, find a REALLY reliable race engine guy that will sleeve the lifter bore. I would never weld in that lifter galley, it will cause all kinds of heat issues.
    What happened to cause the damage?
  15. Camm
    Camm
    Just bad luck.........
  16. tommyd
    tommyd
    from South Indy
    Bet you can get that bored and sleeved for less than a hundred bucks.
  17. Bad Daddy
    Bad Daddy
    Try contacting Chris Zootis in Healdsburg. If he can't do it, I'm sure he can point you in the right direction.
  18. Camm
    Camm
    That would be really nice.............
  19. Camm
    Camm
    I will give him a call. He did a repair on a Harley case for me years ago. Thanks
  20. Brog
    Brog
    Yep..... the question isn't if it could be fixed, it's more of a question of how much money ya got haha
  21. There is a place in Huntington Beach that may be able to repair it or know who can. Pfaff Marine Engines. 714 894-7573
  22. The lufter bores on a hawg were aluminum, they were fondly called mushrooms and bolted on. Probably a little easier to repair than the cast iron hemi.
    I still believe that the hemi block is savable especially being that the piece that broke out is still there. it is just a matter of how involved someone wants to get and if there is a replacement block hiding in the wings.
  23. Camm
    Camm
    Thanks guys i found a guy to fix it..............
  24. bobss396
    bobss396
    Good deal then.
    I had visions on strapping it onto the bed of the Bridgeport and going medieval on it, could be an interesting fix.
    Bob
  25. BJR
    BJR
    Show us some pictures of how they fix it please.
  26. Yes, very interested in some photos of this.
  27. CGkidd
    CGkidd
    I got a buddy here in Wa who has done things like that. I was recently at his shop and saw a 440 block he made into a cross bolt main bottom end. Pretty damn sick looking. I have seen him put back pro stock blocks with main caps completely busted out of them. I will try to post some pics of some of his work.
  28. WhitePunkOnNitro
    WhitePunkOnNitro
    from Middle Tn
    I have fixed stuff like that...and it's alot easier than you might think. I would stick a lifter in the hole, and then GAS WELD, using a plain steel rod, around the lifter. No worries about cracking the block with something like that.
    Build it up thick, and then simply have it bored and bushed when you're done. If you're running a solid lifter, you may not even need to follow through with that step. I did a similar repair to a 426 Hemi block years ago, and never had a problem with it.
