1940 Ford Ignition Swtch Question
Discussion in 'The Hokey Ass Message Board' started by rex1927, Sep 27, 2010.
  1. I purchased a 1940 ford steering column with a missing key and switch is locked.
    How can I remove ignition switch with as little damage to column as possible?
    Do I try to bore it out?
    Going to use a switch in dash on my car.
    Just need it out so steering shaft will turn.
    I did not know ford had locking steering columns in 1940.
    Learn something new every day.
    thanks
    fivefour likes this.
  2. Steve-Cook
    Steve-Cook
    from Garner, NC
    if you can get a locksmith to unlock then you would be good
  3. okiedokie
    okiedokie
    from Ok
    It seems like there was just a post on fordbarn.com by **** Spadaro showing exactly how. Seems like it was originally posted on here.
  4. Bruce Lancaster
    Bruce Lancaster
    Spadaro posted pics recently. Basically, look at the casting below the lock cylinder...you will see a pin driven in there. Drillit...best way is small hole, tap for a screw to pull it out, some people just kill it with a drill. It is very roughly 1/4" deep...if you see br*** coming out, you are a bit too deep! Once pin is out you can pull the cylinder. Key code is stamped on it, so go find the oldest guy at the oldes lock smithery around and get it made.
    If you were working from a complete '40 first step would have been to pull the door lock. If original, it would carry same number and it comes out with just a single set screw.
  5. garcoal
    garcoal
    got to ask a question why does your 1940 steering column have a key switch in it. they didnt put the key switch in the column till late 60s to early 70s. your key switch should be in the dash board. are you putting a newer column in your car. if its out and loose take it to a lock smith and have a key made
  6. Special Ed
    Special Ed
    I believe Ford started putting the key lock on the column in '32...:cool:
  7. Guess I should have stated this at start.I bought this 1940 ford column to put in my 1927 2 door sedan.Ignition switch is in dash of my car.I bought this because it was a good price and was told it would work for side steering with pittman arm up.I had no idea they were locking columns.Just need lock out so steering shaft will turn.Sorry for any confusion guys.It was my fault.
  8. AJofHollywood
    AJofHollywood
    The key only locks and unlocks the column, correct? The switch to the right (in that picture above) is how you turn the ignition on & off, I don't really know. And is it the same though '48?
  9. DD COOPMAN
    DD COOPMAN
    It's always re-***uring to get the straight "scoop" from a guy that knows what he's talkin' about. DD[​IMG]
    eddie_zapien likes this.
  10. 19Fordy
    19Fordy
  11. leebros60
    leebros60
    from new jersey
    garcoal you are just a few years off, just a few.
  12. lothiandon1940
    lothiandon1940
    Cut him some slack. He works at a Kenworth dealer and is in a British car club and drives a '66 T-Bird. With all that going on, he may be a little confused.:rolleyes:
  13. Thanks for the information guys.
    You always come through when I need help.I am ready to tackle it now.
    Thanks again,rex
  14. blackrat40
    blackrat40
    garcoal huh?....another "Know nothing Know it all".
  15. Rocky
    Rocky
    Classified Editor
    How timely. Today I was looking over my extra 40 column that didn't sell at the swap meet. The lever is in the "off" position with no key...looks like someone tried to screwdriver it but when I turned it over the pin was gone already. How convenient for me. Tomorrow I attack the project. Thanks, ****.
  16. navypainter
    navypainter
    What happens when you break the tap off in the hole you just drilled???:confused:
  17. 19Fordy
    19Fordy
    Take it to a place that does EDM - Electric Discharge Machining.
  18. navypainter
    navypainter
    Thanks for the info but I think I might drill the lock, heat the pin and push it out unless anyone objects to that. I don't see how it would hurt anything but then again I've never worked on a 40 ford column before.
  19. greazy john
    greazy john
    i thought all 40 columns came with tilt ?? LOL
  20. navypainter
    navypainter
    Drilled the s#!t out if the ignition switch today. Br*** flying everywhere! Got it out in just a few minutes. Problem solved :)
  21. Rocky
    Rocky
    Classified Editor
    Great! I actually found the key for mine and it's going into my 34 ford coupe.
