'46-'48 Ford Deluxe vs Super Deluxe
Discussion in 'The Hokey Ass Message Board' started by 48Tom, Feb 29, 2012.
  1. Biothree
    Biothree
    1946 Ford & Mercury's had the following numbers: 650,280 to 1,412,709. <O:p</O:p
    Two of my 2 door frames have the numbers 692058 and 1371828 respectively stamped on them. So one was built in August 1945 and the other was one of the last cars built in the 1946 car year. Both frames had the old style shocks.<O:p></O:p>
  2. Bruce Lancaster
    Bruce Lancaster
    My '48 is in the 899 prefix series, so built and sold as a '48, it was apparently built 11-11-1947 at Edgewater with lever shocks.
  3. Biothree
    Biothree
    Both of the '46"s have 99A as the prefix.
  4. Bruce Lancaster
    Bruce Lancaster
    All 239's '39-48 start with 99...they added a year prefix in maybe 1947, 799+1947 239, 899 is '48. A, C, M, and T type suffix on the 99 tell what the ch***is was
  5. 40FordGuy
    40FordGuy
    i think most had the right side tail light installed, when turn signals were available as aftermarket items... Safety was another consideration; Unless it's in a museum, I don't think one will see a std with single tail light these days.
    4TTRUK
  6. 46fatford
    46fatford
    A friend has an early 47 that has a 46 grill, and the side window trim, and crank out vent windows so they were available on 47's atleast early on.
    Matt
  7. Bruce Lancaster
    Bruce Lancaster
    somewhere around '41 was a watershed for taillights...single light models (trucks, standard/special p***enger) started getting dual lights for cars delivered to certain states to meet new local laws. At least p***enger vehicles after '41 all got duals, probably to save trouble of dealing with local differences. Don't know about trucks.
  8. Biothree
    Biothree
    I found something odd that you fellows may be able to answer. I had several rear fenders that were not usable so I took the tail light housings off (they all had left and right side tail lights). All of the tail light housings had one bulb except one and it had two bulbs. One of my parts cars was a 48 so my question is 1) did some '48's have turn signals, thus 2 bulbs, or 2) was this an after market upgrade?
    It certainly gave my the idea of using two bulb when I put my car back togather.
  9. Bruce Lancaster
    Bruce Lancaster
    I believe all '48 type Fords had single two filament bulbs back there, allowing turn signals to be wired right in the same as most American cars of the fifties and sixties. Park lights were single but Ford offered a replacement socket for doubles as part of the Ford turnsignal kit. Double bulbs would fit pretty easily in a '48 tailight, could be a conversion just to get more candle power or a turnsignal conversion using a truck type switch meant for separate brake and signal bulbs.
    From memory, the Ford turn signal kit was actually post-production using '49-50 parts packaged with a special '48 conversion harness. The front socket conversion uses stock '50 type socket.
  10. 48FordFanatic
    48FordFanatic
    from Maine
    I only skimmed the post but didn't see this difference....my 48 Coupe had chrome plated garnish moldings.
  11. Bruce Lancaster
    Bruce Lancaster
    Stock they were dash color, with I think the botton roll painted a tan along the upper edge of upholstery
  12. Bigcheese327
    Bigcheese327
    Was that Ford's "We're not gonna let this stinking Studebaker Champion thing off the ground" model?
    -Dave
  13. Bruce Lancaster
    Bruce Lancaster
    Yeah...remember Bruce McCall's fake 1940's car ads? He did one ad for the "S***liner", showing a dashboard full of empty holes and such...
    These cars were really built for fleet sales and not for the public, so they were pretty rare. The "Deluxe" placed below "Super Deluxe" was the one for regular stingy people.
  14. saxet
    saxet
    from Texas
    My '46 Super Deluxe had a gizmo mounted on the firewall with water hoses going to and fro under the hood, but Gawd knows it sure wasn't a heater!!! :)
  15. psychotitan
    psychotitan
    from LA
    Figured I'd upload my 4 door 48 Ford Super Deluxe.
  16. Atwater Mike
    Atwater Mike
    About taillight housings: Both my '47's housings have the stainless trim on top, but the right one has a large oval around the socket, making bulb changing easy.
    The left one, however, has a hole barely larger than the bulb, making it a real h***le to grab the bulb!
    I know, I need to get some 1" surgical tubing to grab it with...but which year came with the larger access hole???
  17. Bruce Lancaster
    Bruce Lancaster
    Probably just multiple suppliers of that inner part.
  18. [​IMG]
    Uploaded with ImageShack.us
    My 47 Super Deluxe tudor.
    Badged as such. Two ash trays, two visors, horn ring, chrome trim on dash, two arm rests, cigerette lighter, radio, clock (still keeps perfect time!), two ash trays in back seat, "smoker's" windows in back, chrome on the tail lights. Push out vents.
    Brown wool interior, with carpet. No trunk light. Tube shocks in front, levers in back. Supposedly a 60,000 mile four owner car.
  19. Jersey Joe 67
    Jersey Joe 67
    from J Town
    I know this thread has been buried for a while but I was wondering if someone could post a trunk pic of a 46 with a tool tray.
    I'm in the process of replacing the sheet metal in the floors and wanted to see how it looked.
    Thanks
