some of the work from my shop
Discussion in 'The Hokey Ass Message Board' started by cornfieldcustoms, Nov 15, 2011.
  1. YocumBros.
    YocumBros.
    from Raleigh NC
    impressive fab skills!
  2. Pewsplace
    Pewsplace
    Great fabrication and welding skills are obvious in your photos. Keep them coming.
    Lynn
  3. cornfieldcustoms
    cornfieldcustoms
    had some friends come into town over the weekend for the wilmington mile speed runs. while they were here we built this ch***is for his model A truck, just tacked up in the pics until i get the flat 32 front cross member in.
    2x4x 3/16 tube, 4 inch Z up front 11 in the rear, tapered front rails, 1.75 wall tube for the center section
  4. Big Nick
    Big Nick
    Nice work, good for you!
  5. hmmm
    hmmm
    Keep on posting mate....you never stop amazing me with your work. You're an artist....:confused::D:D
  6. hodson
    hodson
    from oklahoma
  7. 58Darlene
    58Darlene
    Had the chance to swing in last weekend, and enjoyed hanging out at the shops and seeing what you've got going on. Great work, and love the projects going on.
  8. cornfieldcustoms
    cornfieldcustoms
    made this roll pan the other day for an O/T car. made completely from scratch, 18 gauge steel. rolled edges, whole thing is crowned and recessed plate box
  9. swimeasy
    swimeasy
  10. Brads MONSTER
    Brads MONSTER
    from Buford GA
    Bad *** keep the pics coming
  11. cornfieldcustoms
    cornfieldcustoms
    have not been doing a ton of cool stuff worth posting on here. a lot trans and rear end swaps........ blah. i have done some more bead rolling on a customer car, and made some bomber seats. here are some pics for proof lol
    some floor pics in a sedan i am working on
    fuel tank cover panel in the same sedan
    and the bomber seats
    all the pieces cut, drilled and bead rolled, all the large holes still need dimpled, and the seat belt holes will be cut out later
    added the side brace on the inside
    and the finished product ( seat 1 of the pair)
    Hollywood-East likes this.
  12. cornfieldcustoms
    cornfieldcustoms
    second seat of the pair starting to go together
  13. cornfieldcustoms
    cornfieldcustoms
    today i did some patch work on my neighbors 57 chevy fenders. i made all the patches and metal worked them in. i got carried away and forgot to take pics before i got the patches tacked in. but you can get the idea.
    to start on the rear lower area of the fenders, to make the patches i first made a cardboard template and transfered it to some sheet metal.
    then cut it out
    the bottom edge has a curved break on it, so to get that is used the bead roller with a tipping die.
    then i had to put a regular break on the back edge. then run it through the shrinker to get the curve to match the original fender
    here is the new (extra) panel
    here are some of the patches tacked in
    all the panels fully welded, ground, and hammered and dollied out smooth
  14. cornfieldcustoms
    cornfieldcustoms
    and some pics of the backside, still need to put the support brace back in
  15. oldrodder43
    oldrodder43
    Great work! Wish I could be there and work with you or at least watch you do body work. Alas!
    I sure would like to be able to do some of that quality metal work.
  16. maddog1949
    maddog1949
    Very impressive
  17. willymakeit
    willymakeit
    I absolutely like nice work. It gives me a place for ideas and the kick in the rear to work on things. Keep posting.
  18. John B
    John B
    I've been right beside Mike while he works. He makes it look effortless.
  19. How much for a piece of metal 14" X 24" with the 32 Ford truck bead? Run the bead side ways on the 24" side about the same depth that you have it from the top. Doing a crew cab on a 32 commercial truck. Would love to see more photos of your made machine to do that with if possible.
    Joe
  20. czuch
    czuch
    from vail az
    Afreeekingmazing!!!!!!!!!!!!
  21. VERY GOOD WORK!
    I am impressed!!
  22. zipoleon
    zipoleon
    Mike does great work, and he's a real nice guy on top of that.
  23. cornfieldcustoms
    cornfieldcustoms
    thanks for the kind words guys
    autoworldcorp, i will have to do some checking and see what i can do on the body line panel
  24. cornfieldcustoms
    cornfieldcustoms
    started some work on the floor of a 31 model a coupe i am building for a customer . added some raised areas on the floor pans for strength and some design. on the trans tunnel i added another raised area in the center and some louvers. still more to come over the next few days
  25. saucerhead
    saucerhead
    Nice. Good to see a local boy with some talent.
  26. cornfieldcustoms
    cornfieldcustoms
    some more work from today
    fabbed up front section of the trans tunnel
    p***enger side toe board
    area of the floor were the fuel tank will sit
    all the lines laid out for the section of the floor that go between the floor pans, and the gas tank area
    the panel made up and in place
    this panel goes behind the area for the fuel tank and makes a small storage area in the rear
    and with the fuel tank in place
  27. sr808
    sr808
    Very nice work.
  28. oldrodder43
    oldrodder43
    My Lord, you are a metal wizard. Such work!
  29. cornfieldcustoms
    cornfieldcustoms
    thanks guys, even though i am not to sure about the wizard part lol
  30. nick_c
    nick_c
    from texas
    Good work. I personally liked the triples sticking out of the hood on that model a
