6 to 12 volt conversion
Discussion in 'The Hokey Ass Message Board' started by 51flathead, Apr 19, 2012.
  1. 51flathead
    51flathead
    what needs to be changed when converting a car from 6 to 12 volt?
  2. 41 C28
    41 C28
    You'll need to change to 12 volt bulbs for sure. The 6 volt bulbs will work ok for about 5 sec. Still running my 6 volt wiper motor on 12 volts.
  3. BurnoutNova
    BurnoutNova
    from USA
    Aside from the obvious stuff like battery, reversed cables (if it was pos ground) and lightbulbs... you need a runtz voltage reducer on each of the gauges and a ceramic resistor on the blower motor. Also need your 12v charging source, so an alternator, or modified generator.
  4. Chipman
    Chipman
    from Oregon
    I am doing the same conversion and found a wide range of answers, but I know you need a 12v coil as well.
    I haven't seen mention though about voltage regulator, fuel sending unit or headlight relay needing to be changed. Any body know about those?
  5. JeffB2
    JeffB2
    from Phoenix,AZ
  6. What make/year?
    Charlie Stephens
  7. bchrismer
    bchrismer
  8. You don't need to change the coil. Fuel sending unit is fine to.
  9. Frankie47
    Frankie47
    from omaha ne.
    Thank you for that....all 12 volt coils are actually 6 volt with a internal or external resistor.:)
  10. Chipman
    Chipman
    from Oregon
    Thanks for all the replies guys. My car is a 49 mercury 4dr sedan. The 12volt conversion seems pretty easy compared to the steering modifications i'm into now. I will have to start a new thread for that one.
