Oldsmobile 425 fenderwell headers where can I get them
Discussion in 'The Hokey Ass Message Board' started by CadillacMat, Oct 27, 2010.
  1. CadillacMat
    CadillacMat
    Im looking for a pair of fenderwell headers for my 55 olds g***er project with a 68 olds 425 in it and I cant find them anywhere, anyone know where I can get them I dont have alot of money or I would have them custom made
  2. squirrel
    I would be shocked to find that any company ever made them. Looks like it's time for you to learn how to build headers. It's not rocket surgery.
  3. OahuEli
    OahuEli
    from Hawaii
    ...or brain science!
  4. 55chieftain
    55chieftain
  5. 1934coupe
    1934coupe
    Nobody makes them for any application. Some times you just have to bite the bullet. If you don't have the experience in gas welding and fitment of tubes you will wind up spending more money than a set would cost.
    In Jegs
    <SCRIPT>addProduct('16740');</SCRIPT>Hedman 58150 - Hedman Headers
    <SCRIPT type=text/javascript> var MAX_WIDTH = 300; var MAX_HEIGHT = 300; function Nexter(imageId, newValue) { do***ent.getElementById(imageId).src=newValue; }</SCRIPT>[​IMG]
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    You can,t build them for that.
    Just some sage advice from some one who has done it.
    Pat
  6. Red71
    Red71
    from Illi-noise
    Take a look at drag boat headers for Olds. they way the come out and up
    may work for you with a little work. That is one of ways I was looking,but
    going to check into BBC headers also.
    hope that helps...
  7. aerorocket
    aerorocket
    from N.E. P.A.
    If your engine is a 68 it is a 455 not a 425 as 67 was the last year olds put the 425 in there cars.
  8. bobwop
    bobwop
    from Arley, AL
    modify a set of BBC headers. Speedy Bill sells them cheap
  9. spikeshotrods
    spikeshotrods
    I made mine from a set of big block Chevy B***et boat headers and a set of car header flanges The primaries tubes are 2 1/4" x and the collectors are 4", a bit on the large side but look cool on a g***er. I'll Post some pics tomorrow.
  10. spikeshotrods
    spikeshotrods
    Pics of my headers
  11. This is what I'd recommend as well...
    I couldn't find anything I liked or that would fit so after 14 hours my friend and I whittled these out in Stainless Steel!
    I really like how Spikeshotrods headers turned out!!!
    Or you can do what Mike from BCR did and get a header flange from Sanderson and build your own car!
  12. Great job... how many 90 degree bends did you cut up????
  13. spikeshotrods
    spikeshotrods
    I didn't need to cut any extra 90's, I used all of the drop from the boat headers, just cut and rotated tubing till it all lined up with the header flanges.
  14. hotroddon
    hotroddon
    Small Block Chevy might be a better place to start considering the port configuration is closer than BBC would be. Just a thought.
  15. 1957Custom
    1957Custom
    from Tulsa Ok
    I helped a guy build a tube ch***is Olds a few years ago. We used big tube smallblock Chevy headers & bought Olds 455 flanged from Hedman. Oldsmobiles have siamesed (sp) center cylinders like a smallblock
  16. OahuEli
    OahuEli
    from Hawaii
    Check out "2Loose" on the Hawaii HAMBer site. He put a blown Olds in a '55 Chevy G***er and has some good pics of how he modified some BBC fenderwell headers. Cool build all the way thru.
  17. Captain Chaos
    Captain Chaos
    from Missery
    SBC will have to small a tube to let that olds breath through .
    Olds headers at swap meets usually go cheap to start with . . Even the SB Olds has the same flange pattern so that makes it even easier.
    You could check with Dave Smith and see if they have anything funky laying around
  18. Mike from Vendetta auto fab cut my flanges out of Stainless however since his p***ing I don't know if the shop is still operating...
  19. 55chieftain
    55chieftain
    My link in post #4
  20. OahuEli
    OahuEli
    from Hawaii
    Damn, I missed that completely! lol
  21. sweets gasser
    sweets gasser
    i know this is an old thread but i just made a set of fenderwells for my 455 olds powered 47willys g***er pu.chopped up a set of flowtechs and added some combo bends from speedway motors.1st time at doing anything like this but i built the entire truck,so not afraid to at least try.jerry.sweet@q.com for pics if you want them 1 5/8 were stock from flowtech.enhances torque!smallblock chevys work best or buy the flanges and build a custom set.i just cut enough tube to leave a small stub and used u bends for my frame uprights and j bends for the downtubes.alot of work but they look and work great
