Old Edsels never die, they just go to Sweden!
Discussion in 'The Hokey Ass Message Board' started by Mats W, Apr 8, 2012.
  1. greg
    greg
    I still get jealous seeing you work under a lift. Great work.
  2. Nads
    Nads
    from Hypocrisy
    Great work duded, I have much admiration for you frozen guys living in the permafrost.
  3. Mats W
    Mats W
    Thanks for the props, guys.
  4. Stefan T
    Stefan T
    from Sweden
    My and Mats lift is verry good to have it been great since we bought it
    /Stefan
  5. Mats W
    Mats W
    Yes, we purchased it together - but we put it in my garage. It often helps out to be able to work as a team and I completely agree the lift is absolutely awesome :cool: !
  6. Mats W
    Mats W
    UPDATE:
    Did fix the cross member to frame connections
    Since there (with one exception) no longer are any welded nuts left I enlarge the holes so I can …
    … weld back a new nut (M10)
    My son helps me out ;)
    Same procedure is repeated twice on the opposite side
    I think this will work just fine :cool:
  7. greg
    greg
    10mm in an edsel:eek:
    I guess you use what ya got.
    I have a stupid question? are your ratchets 3/8 and 1/2 inch drive or metric?:rolleyes:
    you said you didnt have a square bit for the rear drain, but over here it is just the 3/8 ratchet size.
    I guess I have too much time on my hands to think about things like that.:D
  8. Mats W
    Mats W
    I think there are no stupid questions :cool:
    M10 means the threaded part is 10mm thick, the bolt head is 16mm (5/8 inch) wich is slightly bigger than the 9/16 inch ;) I recide in the metric part of the world, and inch size bolts are really scarce around here ...
    I have both 3/8 and 1/2 inch ratchets, but I really couldn't see how any of them could fit the drain plug - perhaps I did not squeeze hard enough :eek:
  9. dmarx
    dmarx
    from Michigan
    Thought I would p*** along pix of this Edsel collection. These are in Lugoff, SC
    Dan
