Mayday, mayday, mayday 2012 banger meat
Discussion in 'The Hokey Ass Message Board' started by Hapydz, May 1, 2012.
  1. Hapydz
    Hapydz
    Here is the banger link list .
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Flat Ernie maintains the monthly link list. Every month is listed:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.billsbangers.com
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    Post #105 of link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/s...=470853&page=6
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/s...84#post6992484
    Engine tuning with a Vacuum gauge
    http://www.centuryperformance.com/tu...e-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/s...61#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/s...d.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculatorfin.jsp
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?...icdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    http://www.scribd.com/doc/22469332/T...e-Ricardo-1931
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/s...470853&page=10
    Maybe these links should be posted early in each months meeting.
    If anyone knows of more, please post them.
  2. Hapydz
    Hapydz
  3. RussTee
    RussTee
    Thanks mate.
  4. RichFox
    RichFox
    A SBC fit under this hood with twin turbos and a big intercooler. My OHC Pinto fit. My DOHC Lotus fit. The Plymouth fit both flathead and OHV. But the Dodge Bros. has to fight me every inch of the way.
  5. RichFox
    RichFox
    See. Again a couple of Dodge pictures kills the thread. Perhaps they should be banned.
  6. zenndog
    zenndog
    from Santa Cruz
    Is there going to be a blister covering the valve cover. Have you picked up the headers from the coater as well?
  7. RichFox
    RichFox
  8. Bigcheese327
    Bigcheese327
    The Dodge Brothers loved to drink and fight. Is it any surprised their engines like to fight also?
  9. Rich, if it was easy everybody would do it.
    John
  10. Bwahahaha- good one, Dave!
  11. MrModelT
    MrModelT
    Finally putting the new motor for my '26 T roadster together..
    :D
  12. noboD
    noboD
    Rich, how close are we to seeing smoke? NO, they should not be banned!!
  13. Crazydaddyo
    Crazydaddyo
    Great looking T!!!!! Anything special in the bottom end? A crank?
    How fun is it going to be to stop all that HP when it gets up to speed?
  14. MrModelT
    MrModelT
    Thanks CD! :D The bottom end is all new with a '26-7 "EE" crank, new bearings, full race cam and a full balance job. Pistons are .080" over aluminum and Valves/seats are 302 SB Ford hardened stainless.
    Running a "Z" head on top with a a Mallory auto-advance dizzy, Burns intake and two special Stromberg 81s dialed down and setup by Uncle Max.
    I would have gone with a '28 Chev or Model A crank, but didn't have the extra $ at the time for that too...plus I don't intend to beat the heck out of it.
  15. RichFox
    RichFox
    Maybe next weekend. Only a few loose ends to do I think.
  16. Crazydaddyo
    Crazydaddyo
    Who's pistons? Hi compreshion? Modern rings? No magnets on flywheel?
  17. MrModelT
    MrModelT
    I can't remember who made them, Egge I think. They are flat tops with modern rings. The "Z" head is a 6:1 high comp head, so I can't run the High-dome pistons.
    I decided to leave the magnets on the flywheel this time to regain my hill climbing power and proper oiling of the bands and clutches. My last motor didn't have magnets and it just wouldn't climb a hill with out down shifting. On the flat level road it would haul...but I got killed on hills.
    With the new motor (and the magnets) she ought to bulldoze up and over hills no problem.
  18. Crazydaddyo
    Crazydaddyo
    When you do get it started make sure you video it and show us!
  19. Crazydaddyo
    Crazydaddyo
    Are you running an oil pump? Bearing material?
  20. MrModelT
    MrModelT
    No oil pump on this one. The rods are drilled w/dippers, but I didn't have the the crank drilled. If I was going to spend the money to do so, it would be a heavy duty crank. I am going to install a High Volume oil line kit to get some extra oil up front so it should be fine.
    Bearing are Babbitt, newly poured.
    Engine is backed by a Chicago 3-speed aux. overdrive unit (behind the stock T 2-speed), a stock rear axle (3.63 gears) with an underslung racing ch***is.
    My build thread is in my signature...tons of pics of my latest rebuild.
  21. RichFox
    RichFox
    If Zenon is here with something to take a video, will do. On my own, no video.
  22. zenndog
    zenndog
    from Santa Cruz
    I will bring my camera and we can shoot a video.
