Brake Pedal War
Discussion in 'The Hokey Ass Message Board' started by Camm, May 13, 2012.
  1. Camm
    Camm
    I can't fit my stock type brake pedal ***embly in my 34 ford. The Hemi and the steering colum have taken up a lot of room. So, i'm thinking about a hanging pedal type set up. I would like to use the corvette manul master cyl. that came with my frame mount kit. Does any body make such a thing??????:confused:
  2. TagMan
    TagMan
    Just to be clear - you want to use hanging pedals with a under-the-floor master cylinder?
  3. JohnEvans
    JohnEvans
    from Phoenix AZ
    Master cylinder don't care where it's mounted. The question is under the cowl or firewall mounting?
  4. hotrod40coupe
    hotrod40coupe
    Look at the setup that Kugel has.
  5. VoodooTwin
    VoodooTwin
    from Noo Yawk
  6. Camm
    Camm
    Firewall mounting. Don't think i would like under the cowl much.
