Projects 41 plymouth coupe 392 hemi build thread
Discussion in 'The Hokey Ass Message Board' started by farmer12, Apr 7, 2010.
  1. farmer12
    farmer12
    Beating and grinding is the only way she'll listen. (the vent frame that is:D:D:D)
  2. Hogman
    Hogman
    from Dallas, TX
    Perfection in every sense of the word, we're expecting nothing less any more Eric.:)
  3. langy
    langy
    No problem mate.
  4. farmer12
    farmer12
    Thank you Hogman.
  5. plmczy
    plmczy
    Looking good.
  6. farmer12
    farmer12
    Thank plmczy. I'm off to work now, but will get busy with the car again next week.
  7. good mornin' Eric,
    come back soon, nice to see your progress on the Plymouth!! the vent window's comin' out great!
    Greets,
    your redneck pal, Carsten :D
  8. farmer12
    farmer12
    Thanks Carsten, looking forward to my next trip to Hamburg. I've got some more time off the coming weeks and hope to show some more progress. I'll just keep battling on, one step at a time and watch my to do list get shorter.
  9. Finnrodder
    Finnrodder
    from Finland
    Looks good!
    I am sure that you'll be happy that you decided to keep the vent windows.
    Have you think about the where to get the gl*** yet?
    I dont know how its in there,but i found out that our local gl*** shop has laminated gl*** too.
    Their main business is to cut window gl*** for houses,but they have cut gl*** for cars and tractors etc.too.So it doesnt always have to be some "special"shop where to get your goods.
  10. farmer12
    farmer12
    Thank you Finnrodder. There is actually a guy about 10 miles from my place that cuts gl*** for tractors, and also cars sometimes. He's meant to be really good and not too expensive. We'll see when the time comes.
  11. langy
    langy
    Eric you would be better off with toughened gl*** in the side windows, laminated has a habit of cracking due to doors closing, just a thought.
  12. farmer12
    farmer12
    Thank you Steve, useful info is always appreciated.
  13. farmer12
    farmer12
    Got stuck into the little window garnish molding today. I first cut it in three pieces and had to change the radius on two corners. Made quite a few relief cuts and just basically spot welded it all until I got the correct shape. Going to do the other one tomorrow and then weld them both up. In the last pic you can see the difference between the two.:D
  14. That's a quite a difference between the original molding and the newly reshaped one. As always, your work is excellent.
    so you gonna chrome all of the garnish moldings when you're done???? :)
  15. Shane Spencer
    Shane Spencer
    good lord what a *****in car. A+ build
  16. Finnrodder
    Finnrodder
    from Finland
    That toughened gl*** thing was new info for me.Well,i guess you are never too old to learn something new.
    Btw,great job with the garnish moulding.Keep it up!
  17. farmer12
    farmer12
    Thank you Hivolt5.0, your comments are always appreciated. I believe that the original mouldings were painted "wood grain", I'll be painting them the same color as the exterior.
  18. farmer12
    farmer12
    Thank you GreenGrenade.:D
  19. farmer12
    farmer12
  20. milwscruffy
    milwscruffy
    Sometimes chopping the roof is the fast part. All the little pieces will drive you crazy modifying them. In the states we call the gl*** tempered gl***. Nice progress Eric.
  21. plmczy
    plmczy
    nice job on those garnishes eric. If I were to do that I would need a couple sets of them, I know i'd mess them up,lol.
  22. farmer12
    farmer12
    Thanks milwscruffy. Even though chopping a roof correctly is not an easy task, I believe its all the small/interior pieces that finish it off. Everything from gl***, weatherstripping, mouldings, etc require modification. Fun but time consuming.
  23. TexasSpeed
    TexasSpeed
    from Texas
    Still working on those roof pieces, uh?
    That speaks a lot about the quality you're striving for in this build. Perfection cannot be rushed. Top notch work as always..
    Maybe one of these days, I'll build something a little harder to build than a Model A. :)
  24. The devil is in the details.
  25. farmer12
    farmer12
    Thank you Tex***peed. Yes, I'm still working on the doors and all the moulding, but the end is in sight!
    You would think it was copy/paste when it comes to making the other window garnish, but there are subtle difference in angles between the two. Not that anyone will be able to see it......both now exactly fit the window they were made for.
    Unfortunately I ran out of time, so I'll be welding them tomorrow.
  26. farmer12
    farmer12
    I think its the details that will set a car apart from others. Few people realise the amount of work that is required to get it to that stage. It's the whole package: planning, fabrication, welding, etc that is the time consuming part. Somehow I forget all of that when I've completed a new part.:D
  27. speed v8
    speed v8
    Great work on those garnishes. Beautiful work.
  28. farmer12
    farmer12
    Thank you speedv8. Patience is the key word.:D
  29. farmer12
    farmer12
    Thanks plmczy. Whenever I'm fabricating something, I just think "its only metal". You can usually correct your mistakes with a bit of patience. I like to take things slow and accurate, instead of just rushing into it. It has worked for me so far.:D
  30. rockable
    rockable
    Great work as usual, Eric!
