Distributor question - Need to get this fixed
Discussion in 'The Hokey Ass Message Board' started by greasemunkee, May 16, 2012.
  1. greasemunkee
    greasemunkee
    from San Diego
    Need to know if I can directly swap out distributor 1112403 with a 1112390 on a 235 Chevy inline 6 engine that came out of a '55 Chevy 3100. I have short time to get my truck back on the road, the 1112403 points adjustment is all chewed up and have the 112390 laying around. Seems like they would be a direct swap, but really not sure. Any help is appreciated.
  2. greasemunkee
    greasemunkee
    from San Diego
  3. gordy80128
    gordy80128
    from Colorado
    I 've have a tiny set of vise grips (~4" overall length) that I've had luck with for dealing with these kinds of problems. Clamp them down on the screw head vertically and then turn the pliers. Just another idea before you s**** the dist. Home Depot and Lowes sell the tiny vise grips (off shore copies) for $5 or less.
    Good luck
  4. greasemunkee
    greasemunkee
    from San Diego
    Gordy, I tried the small vice grips last night with no luck. The top of the screw is just completely destroyed. I now know why they were so far out of whack, the PO just couldn't adjust them right.
    Anyone know if these are direct swaps?
  5. KJSR
    KJSR
    from Utah
    Measure the drive gear dimentions/depth/etc and if they are the same it should just work.
  6. MainProp
    MainProp
  7. AlbuqF-1
    AlbuqF-1
    from NM
    I'd sacrifice the points so you have more room, just dremel off the stationary point and its support. A pair of linemen's pliers with fresh teeth should get that out. If not, dremel off the head of the screw, remove the points plate. You should have enough of the screw threads sticking up to grab, if not, drill out the screw.
  8. greasemunkee
    greasemunkee
    from San Diego
    Hey guys, thanks for the replies. Going to try and shove it in there tomorrow since they measured up the same, so we'll see how that goes. If it doesn't fit for what ever reason, I'll swap the points plate like MainProp suggested. For some reason I didn't even think of that, must be all the exhaust fumes messing with my head. Will post if it fits in case anyone else has a problem and a spare GMC dizzy laying around.
  9. budd
    budd
    that screw doesn't adjust the points does it? the screw that is removed is what holds the points doesn't it?
  10. greasemunkee
    greasemunkee
    from San Diego
    Budd, you are right. the screw that is missing is the one that holds the points down. the problem is with the eccentric screw that you use to adjust the points. the top is so chewed up that you can't get a screwdriver to catch in either direction therefore not allowing the points to be adjusted. that is really the only reason I was looking to replace the dizzy.
  11. budd
    budd
    maybe a dremel with a cut off disk could fix the screw head, so you can still remove the points right?
  12. budd
    budd
    so heres a youtube showing points like yours, you really do not need that screw, it does make sitting the points a little easier but not necessary, pulling the points and filing the hole for the excentric you could then set the points, cheap and dirty maybe but you would be running.
    http://www.youtube.com/watch?v=Ub1RvqeF5B0
  13. 325w
    325w
    Can you remove the plate and get to the s crew on the threaded side. Cut new slot with the Drexel . Got to be a way to get it loose
  14. As long as the shaft length, number of teeth, etc are the same, it should work. This may sound a bit agricultural, but how about just touching the top of that screw with the arc welder so that the rod sticks, then you have more of a "handle" to get the vice grips on.
    Also, the localised heat may get the screw moving easier.
