Windshield wipers on chopped cars?
Discussion in 'The Hokey Ass Message Board' started by 56KUSTOM, May 16, 2012.
  1. 56KUSTOM
    56KUSTOM
    I gotta have some to get inspected.What do you guys do?
  2. slddnmatt
    slddnmatt
    chop them too.
  3. tfeverfred
    tfeverfred
    That was too easy.:D
  4. perhaps you could get away with using those bmw 4" headlight wipers?
  5. Clevername
    Clevername
    1. Tape some wipers on.
    2. Put a bottle of Jack under the seat.
    3. Ask technician to check the rattle under the seat -before inspection.
    4. Get sticker.
  6. Jalopy Joker
    Jalopy Joker
    what kind of car? have a wiper motor? try using VW arms/blades or cut some down.
  7. Gman0046
    Gman0046
    Bought a blade from Big Al's and cut it down.
  8. chopped
    chopped
    I used a wiper and motor from a boat.
  9. chaos10meter
    chaos10meter
    from PA.
    Just cut them down
  10. flamedabone
    flamedabone
    After 15 years of driving my car without wipers, I finally broke down and installed one of teh Speedway 29 dollar el cheapo single wiper kits. It works really, really well. Whenever it rains, I can't help but giggle my *** off.
    I cut the wiper arm and blade down to fit my windshield, wired it up and was done in about 20 minutes. Painted the arm and blade black and you can't even see it.
    Good luck, -Abone.
  11. move to a state w / no inspection:)
    i usually run one on the drivers side and a bullet on the other side and rainex on whole winshield works well at about 70 MPH
  12. gnichols
    gnichols
    from Tampa, FL
    Newport Engineering has a wide variety of wiper arms and blades. And some great wiper ***emblies. Gary
  13. bubmrdrmerc
    bubmrdrmerc
    from oklahoma
    the mercedes headlight ones work out if its super chopped id jus whack down the originals
  14. There are quite a few rear wiper motors that can be made to work in front. I think it was Dodge Omni that I used years ago.
  15. mashed
    mashed
    from 4077th
    Early Jeep arms, blades, or parts/combinations thereof.
  16. ct1932ford
    ct1932ford
    Go fast enough and you won't need wipers:eek:
  17. I don't know if they are still around but there was a hot rod supply outlet called Queens. They had some real nice setups with real short arms.
  18. 56KUSTOM
    56KUSTOM
    Thanks for all the help! I have a '41/'46 Ford 'vert chopped 4.5". I don't care if the wipers work I just want to get thru inspection.
  19. Uh, around here they not only have to be there, they have to work to p*** inspection.
  20. 56KUSTOM
    56KUSTOM
    I'm supprised no one has marketed short wipers and arms with all the chopped cars out there.
  21. They do. Vintique makes arms as small as 6" I believe.
  22. Chopped 66 Bug
    Chopped 66 Bug
    Yes I was going to suggest VW arms and blades too. The early blades are very simple straight rubber pieces pinched in a metal strip that can easily be cut to length.
    Several years ago we had a walk in SOCAL Speed shop store in the Houston area, They stocked shortened wiper arms and blades but I never saw them in the catalog I had.
    Not sure if they were a normally stocked SOCAL item
    Mike
  23. 56KUSTOM
    56KUSTOM
