Back Seat Bounce
Discussion in 'The Hokey Ass Message Board' started by 37_chevy, May 20, 2012.
  1. 37_chevy
    37_chevy
    from Nebraska
    When I had the interior done on my 37 Chevy, the back seat was just re-covered using the original springs. Is there anything I can do to make it less bouncy? :rolleyes:
    I thought about somehow putting some foam in between the springs. Anybody ever had this problem and what did you do about it.
    Thanks!
  2. adam401
    adam401
    The only time I notice my back seat bouncing it seams Like a good thing;)
    Sorry, no real help from me.
  3. gimpyshotrods
    gimpyshotrods
    I don't know if this will help in your case, but I have hog-ringed springs to the adjacent springs, so pushing on one engages a lot more.
  4. phukinartie
    phukinartie
    Cut foam squares a little bigger than the spring and the same length and twist them in the springs. do every other one to start it firms them right up
  5. rgrhoward
    rgrhoward
    I hear a lot of guys running lengths of burlap or jute between the springs to firm up worn out springs. Might give it a go, and its cheap.
  6. 37_chevy
    37_chevy
    from Nebraska
    What kind of foam? Where do you get it?
  7. chubbie
    chubbie
    this is what i did in the '41 i used carpet pad:mad:, too stiff then i used 4 inch square pieces of foam worked great
  8. Model T1
    Model T1
    All of these tips will work.
    Do it quickly. The back seat of a 48 Chevy and 49 Dodge bouncing is why I got married.:(
    I just got promoted to Grenade inspector. Got any to check...Ooops what was this little pin for? Hold this thing while I check!
  9. phukinartie
    phukinartie
    Couch cushion foam!
  10. RagtopBuick66
    RagtopBuick66
    How 'bout baggin your back seat? Then you could adjust the stiffness. What the helll... I mean, they're baggin everything else...
    You know I'm kidding, right?
  11. chubbie
    chubbie
    funny you should mention the grenade.. we were out picking old car parts one day and were doing well, buying most any thing he had. so he says you guys know any thing about these????? AND STARTS HANDING US GRENADES AND MORTERS!!!!!!!!!!! we were handing them back faster then he was pulling them out of a green box!!
  12. wbrw32
    wbrw32
    This is first step before recover,,,then a layer of burlap
    covered with cotton batting,then a 1" piece of foam,,now the cover and pulled very tight...Maybe you should find an upholstery shop that know what they are doing..sorry to be so blunt
  13. wheeler.t
    wheeler.t
    We've attached edge wire across the springs in the opposite direction to stiffen up old springs as well
