I'm not sure what you expected but i'm talking about using them on plain steel exhaust studs. You know...to tighten up the donut to the pipe.
G'day, Most common br*** nut used for exhaust is the 3/8-24. Dorman part number is 949-003. Should be able to get them at almost any Oreilly store. ms
If you are near a good marine hardware store it may be worthwhile to look thru the aisles, they have those and all kinds of other cool stuff
Yup, br*** and steel do not react with each other. Years back, all exhaust studs were sold with br*** nuts only. I've used stainless steel nuts on them too. Of course always with never seize. Bob
X2. Struggling with old rusty factory nuts made me a believer in br*** nuts. But Jim & others are right about anti-seize compound. You know you may take it apart some time in the future. So why not make life easier by planning for that, right?
Never seize is still evident when I dis***emble exhaust parts that have it applied... turns to dust from the heat, but it still works! Bob
Mike Boyd probably has 'em....no wait...balls of hardened steel are needed to drive a fuel altered...
International used to use copper plated bolts for their exhaust manifolds. It was easy to tell which bolts had been replaced bt the PO, they all broke off. The copper plated ones were just like you had usef high temp antiseize. It was friggin' amazing.
